2010-09-27, 13:59
has anyone managed to get Mupen64plus working under Dharma Beta 2 ? I've tried all sorts so far but not having much luck.
Initially tried installing from Apt using
This seemed to install fine, but it is version 1.5 of Mupen (not the latest 1.99.3)
I was able to get this working using Launcher by pointing it at the binary in /usr/games/mupen64plus
However there are a number of bugs within v1.5, mainly with the sound being extremely juddery/stopping and starting all the time. I tried playing around with the jttl_audio.conf file buffers, but nothing seemed to make a difference.
I have now tried uninstalling v1.5 and have downloaded the latest 1.99.3 build from the google code page, in the hope that most/some of the bugs evident in 1.5 will have been ironed out.
This is where I am coming across problems.
At the moment, Mupen64 now fails to load at all. When you install it from the tar.gz file (google code page), it dumps all necessary files into a mupen64...etc folder wherever you extracted the tar.gz (in my case my home folder). The binary is also located in this folder.
I edited my launcher to point at this binary, however each time I now try to load the app, it crashes and dumps straight back to xbmc. It leaves the following code in my /var/log/messages file
I assume this is some kind of fault with my SDL configuration, however I've no idea where to start diagnosing this!
Here is a full paste of my mupen64plus.conf file in case this sheds some light on the subject ... http://pastebin.com/y4v60Ei4
sudo apt-get install mupen64plus
Sep 27 12:03:18 XBMCLive kernel: [ 2095.480751] mupen64plus[2855]: segfault at 7c ip 00416c88 sp bfcb5070 error 4 in libSDL-1.2.so.0.11.3[3e9000+64000]
