2011-02-26, 00:18
2011-02-26, 00:20
2011-02-26, 02:39
2011-02-26, 03:01
2011-02-26, 06:08
2011-02-26, 13:07
2011-02-27, 00:21
aidang Wrote:How can I go about getting this awesome looking info panel? Hell want it!
If Hitcher has no time / interest in that, maybe I'm going to try making a mod / theme.
2011-02-27, 00:57
thesuffering Wrote:im using alaska revisited for better performance with ATV2 and it only has poster wrap or poster fixed, no poster info. how do i add that view?
Those views are part of Alaska Revisited and are fine on my ATV2.
I would guess that you are probably using the Alaska Revisited Mod from the official repo? That could be your problem, I'm not sure what views it has.
2011-02-27, 01:24
Hidd3nFury Wrote:Those views are part of Alaska Revisited and are fine on my ATV2.
its this modification of it:
http://forum.xbmc.org/showthread.php?tid=94938
2011-02-27, 09:58
TomPiXX Wrote:If Hitcher has no time / interest in that, maybe I'm going to try making a mod / theme.
That would be awesome!
2011-02-27, 18:52
2011-02-28, 01:31
2011-02-28, 20:15
It's been in the skin for a while now; what version are you using?
2011-02-28, 20:15
2011-02-28, 20:20
Hitcher Wrote:It's been in the skin for a while now; what version are you using?http://forum.xbmc.org/showthread.php?tid=94938
ive been using this mod of it since the regular alaska revisited seems to be a bit slugglish on the atv2. i suppose i could get a newer update of the skin and then make the changes he suggests to retain the speed
