I was so counting on this becoming great! I used it a while ago and thought it was fantastic, just not ready because of lots of bugs / unfinished bits. Came back for a look only to find doom & gloom
I truly hope you continue working on audio-matic because it's quite unique and is a wonderful concept. Please come back and grace us with another update.
Ok I feel like a complete Idiot here. I cannot get post processing to work, I keep getting errors that say something to the effect of can't access part of the path. I have tried several different settings and <artist>\<album>\<year> just managed to delete the 4 albums I already d/l'd.
I have the path set to the my music folder on the local machine.
Can someone post what I need to fill in to get post processing to work?
Thanks gang
John
Nice project!
Only I have to admit I too have more use for something like Headphones.
Maybe you should consider adding some of the functionality of Audio-Matic to Headphone? As it is a huge effort to include every possible component both projects would certainly benefit from a joined effort. Maybe Audio-Matic could even be transformed into a GUI that works with Headphone?
Hi there
I hope this is the right place to log this issue. Firstly thanks for all the work on audio-matic. When I add an artist in the manage artist section I get a .NET Framework error. Error is "unhandled exception has occured in your application.......... Overload resolution failed because no public 'add' is most specific for thes earguments..........." - and so it goes and then gives me the below in the details section. I select continue but it does not complete. Any ideas?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.AmbiguousMatchException: Overload resolution failed because no Public 'Add' is most specific for these arguments:
'Public Function Add(text As String) As System.Windows.Forms.ListViewItem.ListViewSubItem':
Not most specific.
'Public Function Add(item As System.Windows.Forms.ListViewItem.ListViewSubItem) As System.Windows.Forms.ListViewItem.ListViewSubItem':
Not most specific.
at Microsoft.VisualBasic.CompilerServices.OverloadResolution.ResolveOverloadedCall(String MethodName, List`1 Candidates, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, BindingFlags LookupFlags, Boolean ReportErrors, ResolutionFailure& Failure)
at Microsoft.VisualBasic.CompilerServices.OverloadResolution.ResolveOverloadedCall(String MethodName, MemberInfo[] Members, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, BindingFlags LookupFlags, Boolean ReportErrors, ResolutionFailure& Failure)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ResolveCall(Container BaseReference, String MethodName, MemberInfo[] Members, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, BindingFlags LookupFlags, Boolean ReportErrors, ResolutionFailure& Failure)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.CallMethod(Container BaseReference, String MethodName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, BindingFlags InvocationFlags, Boolean ReportErrors, ResolutionFailure& Failure)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn)
at AudioMatic.frmAdd_Artist.tmrStartDelay_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.239 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Audio-Matic
Assembly Version: 0.27.0.0
Win32 Version: 0.27.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Audio-Matic/Audio-Matic.exe
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.236 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Win32 Version: 4.0.30319.235 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.WMPLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Audio-Matic/AxInterop.WMPLib.DLL
Interop.WMPLib
CodeBase: file:///C:/Program%20Files%20(x86)/Audio-Matic/Interop.WMPLib.DLL
System.Data.SQLite
Assembly Version: 1.0.66.1
Win32 Version: 1.0.66.1
CodeBase: file:///C:/Program%20Files%20(x86)/Audio-Matic/System.Data.SQLite.DLL
System.Data
Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Web
Win32 Version: 4.0.30319.237 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
hi compc,
just one question, currently i all ready have a music collection, is it possible to use the app to rename everything thats all ready downloaded? i want everthing in one naming convention, i have tried moving it to the downloaded older so it can pick it up there, rename it and then move to the final folder, but its not working.
any suggestions?
