2012-01-14, 03:32
2012-01-14, 07:57
@a11599 (weird nickname by the way)
Wanted to test this more thoroughly before replying, and I've found a couple things.
First off, my asound.conf was wrong (happens when you spend months on end getting this damn sync to work :p)
I'd like to share, this might come up in google, thus helping a fella out.
my asound.conf for hdmi on the geforce 210 is this
I had this :
I put 48000 hoping it would help a while back, but it turns out that for content at 44100hz a delay would seep in. (ie: Bad internet tv rips)
Playing around with sync to display, but I've got modelines in place now so I'll leave it as such until I see a judder.
Pass-through content @23.976 (DTS & AC-3) are way more predictably in sync now, and more importantly for WAF, no need to manually enter a -250ms delay.
About the delay, I'm coming to the same conclusion as you are. I'm leaning to -125ms. This after way too many tests reading lips at 10 inches from a 50inch Kuro.
Using a AVR-2600 from Harman Kardon.
About the pull, do what you can! Not sure it's a feature actually, it's just another advanced setting for AV nerds to play with.
Quote:So it does work for you correctly? Eden is in feature freeze so I doubt it will get in, but I can still try to submit a pull to see what others are thinking about it.
pcm.!default {
type plug
slave {
pcm "hw:0,3"
I had this :
pcm.!default {
type plug
slave {
pcm "hw:0,3"
rate 48000
2012-01-14, 16:12
Really 125? I just left it at 250 seems alright to me what do others think
2012-01-14, 21:20
Yeah really, been at 250 for a hell of a long time.
Gave 125 a shot and it's all around closer for my setup for most videos
44100 and 48000.
But this is with this patch you know.
Lemme explain, if I put -250 some videos I have that have mono sound at 44100 would be a bit out, just going in the audio delay part of the skin, bringing it up would put the sound 100% sync.
Now, with -125 don't have to bring up the gui, which really, is the whole point of putting time in this patch!
44100 and 48000.
2012-01-19, 21:55
a11599 Wrote:So it does work for you correctly? Eden is in feature freeze so I doubt it will get in, but I can still try to submit a pull to see what others are thinking about it.I support this
Using it since Sunday, works like a charm, and this will increase the lifetime ot my remote batteries (options => Audio => Audio delay => ....)
And as long as there is no side-effects for people who don't need it (or are ignoring that they do )...
A big thanks so !
2012-01-19, 23:12
Quote:and this will increase the lifetime ot my remote batteries (options => Audio => Audio delay => ....)
Man speaks the truth here!
2012-01-20, 10:47
Considering AE didn't get through, I would love for this to be included in Eden. Or at least in the following nightlies.
2012-01-23, 17:21
hey just so everyone knows, i applyed this patch to the AudioEngine branch and it WORKS!!! i really didnt think it would but it still works as the 24htz oos bug is still present in AudioEngine although many said it was to fix it. but this patch is a good work around if anyone wants to try it checkout my github git://github.com/Albinoman887/xbmc.git then git checkout master+AE+AVDelay (wont actually be pushed for a few mins)
2012-01-23, 17:50
Quote:the 24htz oos bug is still present in AudioEngine
Now that's dissapointing....
2012-01-23, 19:40
Actually I am pretty confident it is not the current audio subsystem causing the delay but something else. So I am not actually surprised that the delay is still required...
2012-01-23, 20:14
Well the first step to recovery is admitting you have a problem I guess
Here's a serious +1 to roll this advancedsetting in eden.
Who can push this through?
2012-01-24, 08:54
+1 for me too. I would love to see this get fixed in time for Eden.
2012-01-25, 04:39
OK so I think recent commits to the AE branch broke this patch its now applying the AV delay for 24 htz a cross all refresh rates can you help me fix it as aeae is going to be merged very soon anyway
2012-01-25, 05:26
disregard previous post, i figured it out, using the diff patch no longer worked but merging your commit in directly did the trick i'm asuming because i was using a diff patch and the code base had changed too much. now it seems to be working as it should, thanks
2012-01-25, 13:47
Is there anyone playing back 24fps material without needing to adjust the delay? If there is, fine. If there isn't, I really think this should make it into heaven. It is a bug, why not fixing it? Definitely not a feature request.
