Hmmmm... these are very worthwile observations. Can you guys pls continue to post your findings as to whether this seems to be just a DTS issue?
I just tried playing a file with DD audio and one with DTS. Looking at the logs this is the only interesting piece I found:
19:26:16 T:2833431408 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
19:26:16 T:2833431408 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(32000.000000, 1)
19:26:16 T:2833431408 DEBUG: CDVDPlayerAudio:: Discontinuity - was:152.902000, should be:0.000000, error:-152.902000
This happens on both files.
Edit: Here's (
http://pastebin.com/raw.php?i=DrcQgvHr) a full partial log from when first playing a file with DD5.1 audio (which doesn't seem to lag, although I'm honestly not 100% certain) and a movie with DTS sound which IIRC lags.
Interesting info.
Great to see movement in this area.
My sync problems, however are codec agnostic.
Every single 23.976 file has to have audio corrected, be it dts,acs or mono aac.
The patch works flawlessly in my setup.
In my case it seems the "discontinuity" value from the logs is the amount I need to delay the audio by. Of course it's practically impossible to be sure of that since nobody can hear a 1ms lag, but I usually set my delay to somewhere between 150 and 200 depending on source.
It's not unusual to see one Global Sync at the start of playback as well.
Hi negge - I do know some of the background to it, and the issues with the time stamps. It's part of the joy of so many rippers/muxers/recoders being out there that it's hit and miss as to whether the sync frames are correct.
If you have the patience to try remuxing some problematic files, please do. The more info on what works/what doesn't the better!
dude its all files, trust me i have spend 100s of hours beating my head against the wall on this one, save the brain cells (and your walls) no other apps do it (some might on files thatactually do have a timestamp problem but not to the consisitanty of xbmc this patch totally fixes it it just has a small bug about clearing its settings from memory so if you use it for anything other then 250ms 24htz oos bug its pointless but.... hey it works
https://github.com/xbmc/xbmc/pull/713
New patch?
Tried to apply this :
https://github.com/xbmc/xbmc/pull/713.patch
got a compile error
Quote: APPLY PATCH: packages/mediacenter/xbmc/patches/xbmc-1fef727-002-av-delay.patch
patching file xbmc/cores/VideoRenderers/RenderManager.cpp
patching file xbmc/cores/VideoRenderers/RenderManager.h
patching file xbmc/cores/dvdplayer/DVDPlayerVideo.cpp
Hunk #1 succeeded at 1110 (offset -3 lines).
patching file xbmc/settings/AdvancedSettings.cpp
Hunk #1 succeeded at 534 (offset -1 lines).
Hunk #2 succeeded at 1087 (offset -3 lines).
patching file xbmc/settings/AdvancedSettings.h
Hunk #3 succeeded at 313 (offset -1 lines).
Hunk #1 succeeded at 535 (offset -1 lines).
Hunk #2 succeeded at 1090 (offset -3 lines).
Hunk #3 succeeded at 314 (offset -1 lines).
patching file xbmc/video/windows/GUIWindowFullScreen.cpp
patching file xbmc/cores/dvdplayer/DVDPlayer.cpp
Hunk #1 succeeded at 2424 (offset -9 lines).
patching file xbmc/cores/dvdplayer/DVDPlayerAudio.cpp
Hunk #1 succeeded at 370 (offset -1 lines).
Hunk #2 succeeded at 575 (offset -1 lines).
Hunk #3 succeeded at 1091 (offset -3 lines).
Hunk #1 succeeded at 1108 (offset -3 lines).
Hunk #2 FAILED at 540.
Hunk #3 succeeded at 1047 (offset -3 lines).
1 out of 3 hunks FAILED -- saving rejects to file xbmc/settings/AdvancedSettings.cpp.rej
make: *** [release] Error 1
Try this one, this is a single patch of all the commits in that pull:
http://pastebin.com/rxjDVyL3. Or you can also get this single diff here:
https://github.com/xbmc/xbmc/pull/713.diff
Also make sure to change your advancedsettings as described in the pull before testing. No new functionality in this patch, just a refactor. But it is always nice to have test reports.
Ok, I'll test this, but it's still not compiling for either :
I'm using the patches in openelec and it's prerty easy I have to drop this in a file and it compiles, butit chokes.
Trying to applythis directly on 1fef727 xbmc beta 3 main
Anyways, adding .diff rather than .patch to the url gives this :
Hunk #1 FAILED at 540.
Hunk #2 succeeded at 1046 (offset -3 lines).
1 out of 2 hunks FAILED -- saving rejects to file xbmc/settings/AdvancedSettings.cpp.rej
Something in mainline is conflicting with the diff. Maybe something was changed in between that does not allow the patch to be applied directly to current master. You can just insert the rejected part manually.
You can't just insert the rejected part manually as far as I know it unpacks the source just runs the patches and aborts.
It's actually pretty slick and they've done a cool job of programming the build process.
Is your branch that different from master?
I did some testing the other day but I haven't found anything by looking at the logs as to what is causing the delay on some files and not on some others. I also tried remuxing a video that was known to have issues with the newest mkvmerge but it had no effect.
What someone should try:
1. Find a video clip that has delay issues.
2. Try any of the following:
* remux with different options in mkvmerge
* remuxing to a different container (like AVI)
* playing file without hardware acceleration (to rule out whether it's e.g. a VDPAU-specific issue)
* anything
There must be something that is causing this aside from the refresh rate change as I have a few videos which do not have any issues even though they play at 24fps.
