I brought a licence quite a while ago, before the XBMC standards were added - it was generally a very good product, as seemed quite stable, so now you've reminded me im going to give it another go!
Zakkieboy Wrote:I brought a licence quite a while ago, before the XBMC standards were added - it was generally a very good product, as seemed quite stable, so now you've reminded me im going to give it another go!
Would love to hear from you how it works. I wouldn't mind to spend the money, but would need to be significantly better / more stable compared to EMM. And of course 100% compliant with XBMC naming conventions.
Thanks for your thoughts!!!
Bad news mate, just had a 10 minute play, and it doesnt seem to have moved any 'closer' to XBMC...
So its a no go for me, unless anyone can tell me otherwise....
Just need to decide if to possiblly break my ember install just to try ember-r?
Zakkieboy Wrote:Just need to decide if to possiblly break my ember install just to try ember-r?
Would suggest to keep Ember and install Ember-R in addition. The original Ember is still the best option in my eyes, but you may want to get started and familiarize with Ember-R. Sooner or later, the original Ember will break...
Cheers mate, great advice - didnt know you could install both at the same time.
