igitur
Junior Member
Does this script work with Dharma, and if so, how do I initiate it?
PatK
Team-Kodi Member
2011-11-21, 22:19
(This post was last modified: 2011-11-22, 00:04 by PatK.)
Tried V1.02 on pre-eden Nove 17th compile with Win7/64 and T!
It deleted 251 (top 250) rated films... and re-rated none. Thought Avatar was one of the top 250.. but I guess it got knocked off? I had trouble connecting while searching for 'Around the world in 80 days'. Multiple tries and it got through the database.. and added some to the 250 list this time. After checking some of the ratings it did do a good job in the end.
Worthwhile plugin, thanks.
Might suggest a user added amount of the time out, perhaps a scrape for MPAA rating (I have many blank) and how about specific directory path... so new adds could be scanned quickly.
Hey,
Just came across this and was wondering, can this be used over the top of my existing scraped data. I use the TMDB scraper and would like the imdb top 250 data added and to update my ratings etc.
Will this upset my current info or compliment it?
2011-11-23, 03:26
(This post was last modified: 2011-11-23, 06:13 by User 55003.)
Hi m4x1m, nice script! Just updated the top250 and all the values are out by a factor of +1.
The Shawshank Redemption is rated as 2 instead of 1
Star Wars Episode IV: A New Hope is rated as 18 instead of 17 and so on.
Great idea though.
Cheers.
Log from dev PC, Win7-64..
14:34:22 T:3620 NOTICE: [Rating Update] - 'The Shawshank Redemption': old position in your db was 1.0, new position from api site is 2.0
14:34:23 T:3620 NOTICE: [Rating Update] - 'Star Wars: Episode V - The Empire Strikes Back': old position in your db was 11.0, new position from api site is 12.0
14:34:24 T:3620 NOTICE: [Rating Update] - 'Star Wars Episode IV - A New Hope': old position in your db was 17.0, new position from api site is 18.0
14:34:26 T:3620 NOTICE: [Rating Update] - 'Star Wars: Episode VI - Return of the Jedi': old position in your db was 98.0, new position from api site is 99.0
14:34:27 T:3620 NOTICE: [Rating Update] - 'Harry Potter and the Deathly Hallows: Part 2': old position in your db was 161.0, new position from api site is 185.0
14:34:28 T:3620 NOTICE: [Rating Update] - 'The Social Network': old position in your db was 226.0, new position from api site is 236.0
