2012-12-05, 06:16
2012-12-05, 17:09
The latest version of artwork downloader will use your local files if there are none available on fanart.tv.
2012-12-06, 12:27
I try artwork downloader version 2.0.11.It's seem to work on movies but not for tv-show.Can anyone help?I think someone have this problem too.
I would like to get it back to the old ways.for my personal tvshow collection,that i add it manually.
(2012-12-06, 13:07)shaktoo Wrote:(2012-12-06, 08:12)Martijn Wrote:Martijn could AD be enabled to "see" local logos etc for custom files that are not on tvdb/imdb ( & will never be as these are personal files) . I have few web only video files + home videos etc that I had gone @ length to make custom nfo's and (crude) logos, cleararts, discarts etc etc. they used to give some WAF & KAF and made a more richer UI . I think I & many others would be indebt & grateful if you could at some point enable picking up of this local arts which are not on any database.Thanks.(2012-12-06, 07:49)Tomkun Wrote: I did run AD and still the logos for TV shows don't work. Movies are working just fine though like I said, so I'm guessing it's just a teething issue.
It won't work if your tvshows don't have a tvdb id number in the database or if there isn't any artwork available at all anywere (fanart.tv or tvdb).
Enable debug log in xbmc and in add-on settings and check what happens with those tvshows. The debug log should tell you all that.
Plus with the hack version part of these logos were picked but others were not .which .db should I erase and rerun the hack version
2012-12-06, 16:08
here I post my log with app's debug on ...tell me if I make a mistake!
http://paste.ubuntu.com/1414758/
thanks!
cheers
thanks!
cheers
2012-12-07, 18:46
@ devilshura : patience .. I'm sure we will get there .. let Martijn work his magic ...
2012-12-08, 05:40
I ran into an issue while running in bulk mode.
I don't believe it is a problem with the script, per se. It seems that some season banner that is attempting to be downloaded has an inappropriately named season 'n/a'. If I disable season banners for TV Shows the script runs normally. It's not a huge deal for me because I don't actually use season banners for anything (just being complete), but I thought I'd point out the potential issue.
Quote:22:15:38 T:2512 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: invalid literal for int() with base 10: 'n/a'
File "C:\Users\<username>\AppData\Roaming\XBMC\addons\script.artwork.downloader\default.py", line 886, in <module>
Main()
File "C:\Users\<username>\AppData\Roaming\XBMC\addons\script.artwork.downloader\default.py", line 112, in __init__
self.download_artwork(self.Medialist, self.tv_providers)
File "C:\Users\<username>\AppData\Roaming\XBMC\addons\script.artwork.downloader\default.py", line 406, in download_artwork
self._download_process()
File "C:\Users\<username>\AppData\Roaming\XBMC\addons\script.artwork.downloader\default.py", line 424, in _download_process
self._download_art(item['art_type'], item['filename'], self.target_artworkdir, item['gui_string'])
File "C:\Users\<username>\AppData\Roaming\XBMC\addons\script.artwork.downloader\default.py", line 521, in _download_art
item['filename'] = (filename % int(artwork['season']))
ValueError: invalid literal for int() with base 10: 'n/a'
2012-12-08, 08:01
I have recently built a new HTPC and therefore setup xbmc-20121206-ae60d24-master from scratch.
For some strange reason Artwork Downloader 12.0.11 won´t run.
I would really appreciate it if someone would take the time and look at this debug log
ArtworkDownloader
and can tell me what I´m doing wrong.
It is a clean debug log.
I´m just starting xbmc,
waiting a few minutes,
starting artwork downloader,
waiting for the script error and exiting xbmc.
edit:
thats interesting:
won´t link to xbmclogs but to the wiki. Have to remember not to name it Debug Log
Thanks for the hint thrak76
edit2:
The problem only occurs if Season Banners under TVShows is activated.
ArtworkDownloader
edit:
thats interesting:
edit2:
2012-12-10, 10:57
well, my fanart problem still bother me...
http://xbmclogs.com/show.php?id=20060
I'm on frodo beta 2, windows7 32 bits...
after cleaning my all library then rescan it ...still no fanart,used fanart donwloader still no fanart, it keep choosing just this one ( don't know why...)
anyone has an isea?
thanks
cheers
anyone has an isea?
thanks
cheers
2012-12-10, 11:06
Your films aren't in separate folders so if you choose the wrong settings this happens.
Don use the setting "use local files" and remove every local artwork file.
2012-12-10, 11:28
well I don't think so...and I already erased all my fanart...even moved my movie file and redone every scan i can...
what am i doing wrong?
edit: ok change the scrapper ( to universal scrapper) remove every fanart and it did the trick!!! weir because I thought I already test this solution but anyway now it works!!!
thank you very much!!
cheers
2012-12-10, 11:33
I know for sure you have. Check the logs yourself.
So this has nothing to do with the script or with with XBMC.
It's simply how you set your sources and your folder layout
PHP Code:
02:21:00 T:6104 DEBUG: Artwork Downloader: Processing media: Paprika
02:21:00 T:6104 DEBUG: Artwork Downloader: Provider ID: tt0098063
02:21:00 T:6104 DEBUG: Artwork Downloader: Media path: [u'K:\\Video\\films']
2012-12-10, 12:18
thanks martijn
sorry to have bother you with my nooby questions...I edit my precedent post, now it works...
thanks !!
cheers
thanks !!
cheers
2012-12-10, 17:50
Banner not found!
clearart not found!
clearlogo not found!
landscape not found!
[every movie in DB]
I have spent a couple of days trying to fix this problem on my own, but since i am not blessed with programing skills, i have not been able to.
I recently 'discovered' Aeon MQ 4 and because of it, i discovered this app. Well long story short, I organized all of my Movies into separate folders with name of the file and the year (i.e F:\Media\Movies\Battle Los Angeles(2011)) and my T.V shows are organized as follows M:\TV Shows\The Mentalist\The Mentalist - Season 1\The.Mentalist.S01.E01.avi
So i hope my structure is not the issue. Now when running this script the first time, i downloaded something like 1500 images. They all went into etrafanart and extrathumbs, and it worked great. BUT...... I can not seem to get a single clearart thumb or banner. Now like i said i have been reading about this for some time, and i doubt that it is because the art has not been made yet.
So just tell me what i am doing wrong and i will fix it.
System Specs
Win 7 x64 Ulti
AMD 965BE
16GB RAM
Movies on a 1TB WD SATA drive
TV shows on a 1TB WD MyBook
Running Frodo Beta 2
Skin is Aeon MQ4
Install of XBMC and Aeon are fresh (after revo uninstall) i cleared all images from system before installing each of them.
log file: Log File
Additional Log File: bigger one
Some Screen shots
I hope that i have provided enough information
clearart not found!
[every movie in DB]
System Specs
Win 7 x64 Ulti
AMD 965BE
16GB RAM
Skin is Aeon MQ4
log file: Log File
Some Screen shots
