If you have done that effort already - why don't you just implement the rendercapture interface in XBMC for it so it can be used with the official addon? I don't want a second boblight addon just for RBPI tbh ...
AppleTV4/iPhone/iPod/iPad: HowTo find debug logs and everything else which the devs like so much:
click here
HowTo setup NFS for Kodi:
NFS (wiki)
HowTo configure avahi (zeroconf):
Avahi_Zeroconf (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
brooc
Junior Member
Just read the boblight addon code and it looks like it loads libboblight.so and calls functions from there.
Why would I need to implement the rendercapture interface?
Seems like all I need to do is compile my code into libboblight.so and have the addon call my functions from my grabber...
Is that not correct?
wolfgr
Junior Member
for example screen's white seems blue at the leds,like over saturated
OK I succesfully installed my Leds , using Boblight on windows and Boblight addons.
Now few questions since I am new in that project.
Any Option to changes colors when playing music with XBMC? maybe just fading rainbow colors or something else to make it cool?
Any Option to make the leds work out from XBMC? like in chrome? youtube etc..
and, I have IR Remote connected to my pc, and way to command the leds (in XBMC) to turn off\on ? I think there are option, cause bobligt addon have "Disable" option in his configration, so maybe to Create Custom Key that Enable\Disable This Option?
Thank You!
TeKo
Posting Freak
Nothing for music, you can use the static light.
Use XBMC youtube addon or Prismatik software for everything not XBMC.
No key shortcuts I think.
ok.
I used the "B" Keymap to bring the addon configration, from there i can disable the light when I watching video, good enough.
Now, For start, I Though "FAST" mode is cool cause I Watch Animation video (Lion King etc..), but yesterday I Watched Action Movie, and I was preaty annoying, a lots of color changing so fast and them bright and the video is dark... so I Tried Custom option, but Custom does not work at all! its turning them down
You need to configure your custom preset - it works definitly same like the slow and fast presets (just with custom values - so if it stays down on your side - your custom values are invalid somehow...).
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
