TeKo
Posting Freak
Since lightpack is supported by boblight now does anyone have one? I would like to see the final product in action and how it compares to the diy builds.
hi, is there any way to force boblight to recognize what is really on the screen and not what is oin the movie ?
why ?
cause i often zoom movies to eliminate black bars, but lights are showing still unzoomed picture
how can i force them to show what is really on screen ?
when i had windows/xbmc there lightpack works perfect
my rig:
amd e350, radeon,
when i play movie, right.bottom corner video,settings, and zoom.amount,
so, is there any solution to my problem ?
2013-09-19, 10:05
(This post was last modified: 2013-09-19, 10:06 by Memphiz.)
No its not implemented to obey the zoomed rect. (needs changes in the core of XBMC - can't be solved by updating the addon only...)
AppleTV4/iPhone/iPod/iPad: HowTo find debug logs and everything else which the devs like so much:
click here
HowTo setup NFS for Kodi:
NFS (wiki)
HowTo configure avahi (zeroconf):
Avahi_Zeroconf (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
so no hope for me ? damn i have 64" tv with 9mm frame, lights look awesome but only on 16:9 material, those black bars are ruining everything
Depends if someone feels like looking into it (not me). I told it bobo1on1 - no clue if he will get a Crack at it.
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
TeKo
Posting Freak
You can create a 2nd boblight.conf for movies with hardcoded blackborders.
But that would man that you have to restart boblight everytime you switch from zoomed to normal.
