2016-05-05, 06:03
Thank you...disabling Mediacodec surface fixed the issue
(2014-02-10, 22:12)schumi2004 Wrote:(2014-02-10, 19:11)bry- Wrote:(2014-01-16, 19:42)teeedubb Wrote: Sorry man, my script will be of no use then.
@teeedubb - you have info on the script. I have a buddy with OE that would like to try and use it.
is it possible to only have the lights on when media is playing?
To turn boblight off and on via remote?
Try this:
toggle_boblight_service.py (place in preferred folder)
Code:import xbmc
cmd = '{"jsonrpc": "2.0", "method": "Addons.SetAddonEnabled", '
cmd += '"params": { "addonid": "script.xbmc.boblight", "enabled": "toggle" }, "id": 1}'
Keymap entry:
Code:<hash>RunScript(special://profile/scripts/toggle_boblight_service.py)</hash>
00:49:45 T:139863790938176 DEBUG: OnKey: 252 (0xfc) pressed, action is RunScript(special://profile/scripts/toggle_boblight_service.py)
00:49:45 T:139861195998976 DEBUG: Thread LanguageInvoker start, auto delete: false
00:49:45 T:139861195998976 INFO: initializing python engine.
00:49:45 T:139861195998976 DEBUG: CPythonInvoker(22, special://profile/scripts/toggle_boblight_service.py): start processing
00:49:45 T:139861195998976 DEBUG: -->Python Interpreter Initialized<--
00:49:45 T:139861195998976 DEBUG: CPythonInvoker(22, special://profile/scripts/toggle_boblight_service.py): the source file to load is "special://profile/scripts/toggle_boblight_service.py" ("/storage/.kodi/userdata/scripts/toggle_boblight_service.py")
00:49:45 T:139861195998976 WARNING: CPythonInvoker(22): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
00:49:45 T:139861195998976 DEBUG: CPythonInvoker(22, special://profile/scripts/toggle_boblight_service.py): setting the Python path to /storage/.kodi/userdata/scripts:/storage/.kodi/addons/script.module.beautifulsoup4/lib:/storage/.kodi/addons/script.module.httplib2/lib:/storage/.kodi/addons/script.module.myconnpy/lib:/storage/.kodi/addons/script.module.beautifulsoup/lib:/storage/.kodi/addons/script.module.pyxbmct/lib:/storage/.kodi/addons/script.common.plugin.cache/lib:/storage/.kodi/addons/script.module.pytz/lib:/storage/.kodi/addons/script.module.actionhandler/lib:/storage/.kodi/addons/script.module.t9.search/lib:/storage/.kodi/addons/script.module.buggalo/lib:/storage/.kodi/addons/script.module.googleapi/lib:/storage/.kodi/addons/script.module.addon.signals/lib:/storage/.kodi/addons/script.module.t0mm0.common/lib:/storage/.kodi/addons/script.module.autocompletion/lib:/storage/.kodi/addons/script.module.six/lib:/storage/.kodi/addons/script.module.chardet/lib:/storage/.kodi/addons/script.module.simplejson/lib:/storage/.kodi/addons/script.module.youtube.dl/lib:/storage/.kodi/addons/script.module.addon.common/lib:/usr/share/kodi/addons/script.module.pil/lib:/storage/.kodi/addons/script.module.simple.downloader/lib:/storage/.kodi/addons/script.module.uritemplate/lib:/storage/.kodi/addons/script.module.requests/lib:/storage/.kodi/addons/script.module.urlresolver/lib:/storage/.kodi/addons/script.module.oauth2client/lib:/storage/.kodi/addons/script.module.yaml/lib:/storage/.kodi/addons/script.module.routing/lib:/storage/.kodi/addons/script.module.hubparentalcontrol/lib:/storage/.kodi/addons/script.module.parsedom/lib:/storage/.kodi/addons/script.module.elementtree/lib:/storage/.kodi/addons/script.module.metahandler/lib:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gtk-2.0
00:49:45 T:139861195998976 DEBUG: CPythonInvoker(22, special://profile/scripts/toggle_boblight_service.py): entering source directory /storage/.kodi/userdata/scripts
00:49:45 T:139861195998976 INFO: CPythonInvoker(22, special://profile/scripts/toggle_boblight_service.py): script successfully run
00:49:45 T:139861195998976 INFO: Python script stopped
00:49:45 T:139861195998976 DEBUG: Thread LanguageInvoker 139861195998976 terminating
(2016-06-08, 07:15)Memphiz Wrote: disable some android specific surface rendering stuff (can't recall the exact name) - its mentioned a couple of posts back in this thread by martijn iirc.
Quote:13:36:18 T:140541179320064 DEBUG: ### [Kodi Boblight] - settings() - handleCategory(tvshow)
13:36:18 T:140541179320064 DEBUG: ### [Kodi Boblight] - settings() - handleGlobalSettings
13:36:18 T:140541179320064 DEBUG: ### [Kodi Boblight] - settings() - handleStaticBgSettings
13:36:18 T:140541179320064 DEBUG: ### [Kodi Boblight] - settings() - handleStereoscopic(False) - disableon3d (False)
