2012-01-31, 17:35
I have a few old "The Men From The Ministry" radio episodes that won't play in either XBMC Eden beta 1\2.
Have no problems with any other audio, (FLAC\5.1\MP3 mono in avi\anything else). Am using "plughw:0,9" for the audio output for my nvidia GT430. Have tried setting 2.1 output as this used to fix some mono avi on my old setup over spdif...
Anyway here's the file statistics...
Format : MPEG Audio
File size : 6.65 MiB
Duration : 29mn 2s
Overall bit rate : 32.0 Kbps
Album : The Men From The Ministry
Track name : The Great Footwear Scandal
Track name/Position : 02
Performer : The Men From The Ministry
Audio
Format : MPEG Audio
Format version : Version 2
Format profile : Layer 3
Duration : 29mn 10s
Bit rate mode : Constant
Bit rate : 32.0 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Compression mode : Lossy
Stream size : 6.65 MiB (100%)
Here's the mp3 in question if anyone would like to test for success\bug checking.
It's about 45 years old from the BBC and not commercially exploited and of very bad quality low bitrate recorded from radio, provided purely for analytical purposes, so I don't see any copyright issues but please remove if it is a problem. Thanks...
https://rapidshare.com/files/3858133459/...08.30_.mp3
EDIT - Basically, audio with 22khz\32khz sampling rate results in no sound, but the audio is being played correctly from looking at the "visual spectrum" visualization. The input indicator on my receiver flashes "HDMI", as if it had a loose cable. But plays all over content fine and "HDMI" stays solid for that.
Format : MPEG Audio
Duration : 29mn 2s
Audio
Format : MPEG Audio
Duration : 29mn 10s
