have somebody the first version? like in the video?
I like the left media toolbar.
2014-02-17, 05:05
(This post was last modified: 2014-02-17, 05:06 by Almaz.)
I need help to remove the button VOLUME in the right corner. Can somebody point me to the right file, where I can delete the button? Also I need to create a button which opens directly Videos -> Files. Please give me a few hints to modify XML files.
Thank you, this is not what i want , but help me a litlle.
2014-02-18, 18:48
(This post was last modified: 2014-02-18, 18:53 by Spinner65.)
EDIT: Wrong thread... Sorry moved to correct one.
bluc
Senior Member
How do I hide the cursor while using this skin? Kind of defeats the purpose of a touch skin if there is a cursor.
There's an addons section on the main page. Doesnt that do what you want?
bluc
Senior Member
Just a though but this skin would be an awesome frontend for a touchscreen jukebox. And what would be awesome if the skin had a music fanart scraper that downloaded music artist fanart from the web to designated folder than it changed the main background picture to match the now playing artist (if anyone uses "zplayer" or "ubermusic? on android you would know what I mean). would really make this skin awesome.
no subtitles download yet?
Hello,
Is there a way to make all lists to default to thumbnails? I have tried setting Myvideonav.xml to 500 for thumbnails but it doesn't seem to help. I am almost certain this method worked for the Confluence skin. Any help would be greatly appreciated.
Figured it out! No need for help. Thanks anyway.
