2012-04-24, 04:03
xbmc 11 (eden) crashes at start up on my ubuntu 11.10 . Is there a fix or workaround?
Latest crash log:
################# LOG FILE ##################
20:46:23 T:3043944192 NOTICE: -------------------------------------------------
20:46:23 T:3043944192 NOTICE: Starting XBMC (11.0 Git:Unknown), Platform: Linux
(Ubuntu 11.10, 3.0.0-17-generic-pae i686). Built on Mar 24 2012
20:46:23 T:3043944192 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:46:23 T:3043944192 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:46:23 T:3043944192 NOTICE: special://masterprofile/ is mapped to: /home/home
user/.xbmc/userdata
20:46:23 T:3043944192 NOTICE: special://home/ is mapped to: /home/homeuser/.xbm
c
20:46:23 T:3043944192 NOTICE: special://temp/ is mapped to: /home/homeuser/.xbm
c/temp
20:46:23 T:3043944192 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
20:46:23 T:3043944192 NOTICE: Local hostname: mediapc
20:46:23 T:3043944192 NOTICE: Log File is located: /home/homeuser/.xbmc/temp/xb
mc.log
20:46:23 T:3043944192 NOTICE: Setup SDL
20:46:23 T:3043944192 NOTICE: load settings...
20:46:23 T:3043944192 NOTICE: special://profile/ is mapped to: special://master
profile/
20:46:23 T:3043944192 NOTICE: loading special://masterprofile/guisettings.xml
20:46:23 T:3043944192 NOTICE: Getting hardware information now...
20:46:23 T:3043944192 NOTICE: Checking resolution 12
20:46:23 T:3043944192 NOTICE: Loading player core factory settings from special
://xbmc/system/playercorefactory.xml.
20:46:23 T:3043944192 NOTICE: Loaded playercorefactory configuration
://masterprofile/playercorefactory.xml.
20:46:23 T:3043944192 NOTICE: special://masterprofile/playercorefactory.xml doe
s not exist. Skipping.
20:46:23 T:3043944192 NOTICE: No settings file to load (special://xbmc/system/a
dvancedsettings.xml)
20:46:23 T:3043944192 NOTICE: No settings file to load (special://masterprofile
/advancedsettings.xml)
20:46:23 T:3043944192 NOTICE: Default DVD Player: dvdplayer
20:46:23 T:3043944192 NOTICE: Default Video Player: dvdplayer
20:46:23 T:3043944192 NOTICE: Default Audio Player: paplayer
20:46:23 T:3043944192 NOTICE: Disabled debug logging due to GUI setting. Level
0.
20:46:23 T:3043944192 NOTICE: Log level changed to 0
20:46:23 T:3043944192 NOTICE: Loading media sources from special://masterprofil
e/sources.xml
20:46:23 T:3043944192 NOTICE: Using visual 0x22
20:46:23 T:3043944192 NOTICE: CRenderSystemGL::CheckOpenGLQuirks - unable to pa
rse mesa version string
20:46:23 T:3043944192 NOTICE: GL_VENDOR = Tungsten Graphics, Inc
20:46:23 T:3043944192 NOTICE: GL_RENDERER = Mesa DRI Intel® 965Q x86/MMX/SSE2
20:46:23 T:3043944192 NOTICE: GL_VERSION = 2.1 Mesa 7.11
20:46:23 T:3043944192 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
20:46:23 T:3043944192 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL
_EXT_bgra GL_EXT_blend_color GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_bl
end_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_
texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture G
L_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_
elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_E
XT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_
SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_
framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_dr
aw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB
_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_fu
nc_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_
EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL
_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texg
en_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture
_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_textur
e_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle
GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow
GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 G
L_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_ste
ncil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1
GL_APPLE_client_storage GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_A
RB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_obj
ects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_textu
re_env_combine3 GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_M
ESA_ycbcr_texture GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_
float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_t
exture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separa
te GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float G
L_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_rectang
le GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rec
tangle GL_EXT_texture_sRGB GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_
EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeabl
e GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT
_gpu_program_parameters GL_EXT_texture_env_combine GL_EXT_texture_sRGB_decode GL
_OES_EGL_image GL_ARB_copy_buffer GL_ARB_half_float_vertex GL_ARB_map_buffer_ran
ge GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_sepa
rate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_condit
ional_render GL_ARB_ES2_compatibility GL_ARB_draw_elements_base_vertex GL_ARB_ex
plicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex
GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_EX
T_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robus
tness
20:46:23 T:3043944192 ERROR: GLX: Same window as before, refreshing context
20:46:24 T:3043944192 NOTICE: UDisks: Added /media/Storage
20:46:24 T:3043944192 NOTICE: start dvd mediatype detection
20:46:24 T:3043944192 NOTICE: initializing playlistplayer
20:46:24 T:3043944192 NOTICE: DONE initializing playlistplayer
20:46:24 T:3043944192 NOTICE: UpdateLibraries - Starting video library startup
scan
20:46:24 T:3043944192 NOTICE: initialize done
20:46:24 T:3043944192 NOTICE: Running the application...
20:46:24 T:3043944192 NOTICE: Webserver: Starting...
20:46:24 T:3043944192 NOTICE: WebServer: Started the webserver
20:46:24 T:2870999920 NOTICE: VideoInfoScanner: Starting scan ..
20:46:24 T:2870999920 ERROR: SQL: SQL error or missing database
Query: select path.strContent,path.s
trScraper,path.scanRecursive,path.useFolderNames,path.strSettings,path.noUpdate,
path.exclude from path where path.idPath=1
20:46:24 T:2870999920 ERROR: GetScraperForPath failed
path.exclude from path where path.idPath=2
path.exclude from path where path.idPath=11
20:46:24 T:3043944192 NOTICE: starting upnp server
20:46:24 T:3043944192 NOTICE: starting upnp renderer
20:46:24 T:2881174384 NOTICE: -->Python Interpreter Initialized<--
20:46:24 T:3043944192 NOTICE: ES: Starting event server
20:46:24 T:2756692848 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:46:24 T:3043944192 NOTICE: starting zeroconf publishing
20:46:24 T:2756692848 NOTICE: UDP: Listening on port 9777
20:46:24 T:2870999920 NOTICE: VideoInfoScanner: Finished scan. Scanning for vid
eo info took 00:00
20:46:24 T:2881174384 NOTICE: downloader ARGV: ['']
20:46:24 T:2862607216 NOTICE: -->Python Interpreter Initialized<--
20:46:24 T:2781870960 NOTICE: -->Python Interpreter Initialized<--
20:46:24 T:2862607216 NOTICE: StorageServer Module loaded RUN
20:46:24 T:2862607216 NOTICE: StorageClient-0.9.2 Starting server
20:46:24 T:2862607216 NOTICE: StorageServer-0.9.2 Storage Server starting /home
/homeuser/.xbmc/userdata/Database/commoncache.db
20:46:25 T:3043944192 ERROR: XLCDproc::Connect - Unable to connect to host, LC
Dd not running?
20:46:25 T:3043944192 ERROR: XLCDproc::Initialize - Connect failed. Retry in 4
seconds.
20:46:26 T:3043944192 ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invali
d Pixmap or Window parameter), type:0, serial:309, error_code:9, request_code:13
7 minor_code:8
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Full crash log:
http://pastebin.com/2vg4FJsf
Latest crash log:
user/.xbmc/userdata
c
c/temp
mc.log
profile/
0.
e/sources.xml
tness
scan
eo info took 00:00
Dd not running?
seconds.
7 minor_code:8
Full crash log:
