Please do the xbmc log thingy again and post the link you get per e-mail not only the number.
AppleTV4/iPhone/iPod/iPad: HowTo find debug logs and everything else which the devs like so much:
click here
HowTo setup NFS for Kodi:
NFS (wiki)
HowTo configure avahi (zeroconf):
Avahi_Zeroconf (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
NedScott help here - i don't know nothing about that log addon, but it seems its only getting crashlogs instead of log files.
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
I will have to check when I get home and can test directly on an ATV2. I tried the Log Uploader on Mac OS X and it worked fine, plus I didn't see any options to upload different logs.
2012-05-10, 09:48
(This post was last modified: 2012-05-10, 09:49 by Memphiz.)
Well i'm still wondering if you use that log addon in the right way. On other posts the link shows the right log. In your case it allways shows an outdated crashlog which doesn't give me any information.
I doubt it has something to do with DLNA tbh. But without the log i'm stumped.
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
Hi Memphiz, Im not sure how i could stuff that up, would i still get an email with a link to the pastebin if i was doing it wrong?
It's not just my ipad, but also my appletv1, macbook pro and iphone4 that get the same error2: share not avaiable message.
My IP address for my airpot is different to my modem also, I have tried to ad both with the shared drive but keep getting the same error and I have done this with success previously very easily as you guy's have made it, which was great.
But my macbook pro shows my airport express and shared drive and i can access all my movies to watch, just not with xbmc. Would a re jailbreak of my devices fix this?
Cheers
Thanks Memphiz, I'll give it a go tonight.
Cheers
that thing with the IP address 10.0.1.2 is my airport express router.
I have my phone line connected to my netgear modem and then hooked up with ethernet cable from my modem to my airport express, same as I always have, not sure why it would be causing an issue now.
When I open network preferences on my macbook pro it says I'm connected to Ty's Network and has the IP address 10.0.1.2
When I in finder my airport express shows up shared and don't need a password to enter into it to access my shared drive.
Would the username and password for the samba source be from when I set up my network fro the airport?.
I know this is more about networks than xbmc, but could this help?
Cheers
I ave just gone through my airport utility in applications folder and with the setup it says:
Airport Extreme Name: Ty's Airport
IP Address: 10.0.1.1
Version.... and then Airport ID
But still in network preferences it says my IP address is 10.0.1.2.
I have tried to ad both as a new network location on xbmc and get the same error.
Is this setup right with having two different IP addresses for the same network?
Thanks for your help Memphiz
Hi guy's, it's working.
I just did a software update for the airport express and found out my actual IP address is 60.240.178.20, on the settings of airport utility under the summary tab i discovered this.
Also in airport utility under the disks tab under file sharing I had to change the Airport Disks Guest Access to read and write and also include the Airport Extreme password.
These settings were not showing before on my Airport Utility before the software update so I didn't have the option to change these. But all is good now.
Thank you so much for all your help with this, I appreciate your time and effort in assisting me.
You've been great, stoked I have now got the best media tool on all my devices again.
Cheers
