2012-05-07, 19:23
Anybody (devs) here know if sometime support out of the box for this controller will come?
(2012-05-08, 19:07)HenryFord Wrote: So - the driver is currently working fine, only XBMC doesn't pick it up?*moving trough menus by pressing digital buttons
Then follow my thread here - it explains to you, how you can setup your controller for usage with XBMC (i.e.: You have to build a custom keymap):
http://forum.xbmc.org/showthread.php?tid=89630
*=This is what I meant with "information": Please, if you want help, post everything regarding your problem:
What doesn't work, but should?
Quote:How doesn't it work?I press and nothing happen
Quote:What did you expect to happen instead?it moves in the menu
Quote:Does it work with other programs?yes, for example games.
Quote:A logfile. Please... always a debug-logfile if you want in-depth help.I tested xbmc some year ago with userspace driver (xboxdrv) and it worked but I had problems with games so, instead of switching drivers I decided to not use xbmc.
You could, for example, have already posted way more information - that you already used the userspace-driver for example.
(2012-05-08, 19:24)fabioamd87 Wrote: now I'm asking, is possible to have a menu in xbmc to configure the gamepad keys if it isn't able to autorecognize it?That would be a feature suggestion - post it here, it will get more attention this way:
