[RELEASE] Skin XML Converter + Formatter 1.0
Thaught it would be best to make a new thread for this...
At the moment the tool can:
- convert between 1080 and 720 resolutions
- convert encoding
- change indenting and format the code
- remove trailing whitespaces
- change EOL
- add headers
- scale animation times/delays (useful to get rid of effectslowdown values <> 1 in addons.xml)
- check for unused and undefined includes
- start a script involving texturepacker to build the skin (thx to JezzX / Hitcher for the batch script)
here´s the download
https://github.com/phil65/xmlconvertgui/...licRelease
and here the according github repo
texture and font checking not workin properly atm
if you want to use the script easiest way is to clone the repo.
cheers
- convert encoding
- change EOL
- add headers
here´s the download
cheers
