Hitcher
Team-Kodi Member
Thanks, at least my coding wasn't to blame.
worked thanks Martijn! the old watchlist script let me play from path which is what confused me and looks like a misread the wiki! my bad.
2012-10-12, 18:06
(This post was last modified: 2012-10-12, 19:06 by Martijn.)
so i'm the only one with the script failing on startup heres a snippit from the log
2012-10-12, 18:57
(This post was last modified: 2012-10-12, 18:57 by Hack_kid.)
found the problem it has a problem with rared archives. here is the if statement causing it the crash removing it allows it to run
# Fixes problems with rared movies and multipath
if path.startswith("rar://"):
path = [os.path.split(urllib.url2pathname(path.replace("rar://","")))[0]]
elif path.startswith("multipath://"):
temp_path = path.replace("multipath://","").split('%2f/')
path = []
for item in temp_path:
path.append(urllib.url2pathname(item))
BTW
I hate log snippets on the forum. so don't do that
Use pastebin
`Black
Team-Kodi Member
Does RandomAlbum.%d.Title work for anyone?
`Black
Team-Kodi Member
Seems that it stopped working with the nightly from Oct 10.
