I use XBMC on ATV2 and it takes forever to go through a lot of the episodes and mark them watched manually after I have downloaded many seasons, and while I am midway through watching them from before.
Also sometimes I watch TV shows in two modi, I follow new episodes while I am re-seeing an older season.
Hitcher
Team-Kodi Member
No problem, I did the same many years ago when I still used the Xbox for XBMC.
This is a great little bundle...
I'm interested in getting the recommendation to work on my xbmc instance and am comfortable enough to try the customizations to Confluence myself, but does anyone know how the recommendation engine works? what does it use to base its recommendations?
eeyore
Junior Member
I am currently using aeon MQ5 I have two music smart playlists (audiobooks and non-audibooks) that I have added to the main menu. The widgets will not populate when the smart playlist is set to 'artists' but it will populate if the smart playlist is set to 'albums'. Is this some sort of error on my part or a limitation of the plug-in?
Thanks for any help
Anyone had any luck getting .strm files working with this? It's brilliant, but hard to use when the majority of your library is composed of .strm files. I know it works fine with confluence mod but no such luck with xperience1080++
Hi, i read on page 1 that this script is based on randomandlastitem script,
So does it mean i can use it for say,
populating Ace's main menu with Last Action Movies, High rated (Rating>6) Sci-fi Movies ?
Can i use it the same way with randomandlastitem?
