Hitcher
Team-Kodi Member
Better of asking in the Aeon MQ5 forum.
I did they ignored the question lol
The skin widgets does not always display the correct poster for tv shows wich are spreaded over multiple locations
For example:
Drive 1: doctor who seasons 1-5
Drive 2: doctor who seasons 6-8
When choosing the newest artwork for display, it displays the right one in the library but the skin widget in the homescreen displays some old artwork, probably stored alongside the older seasons.
I love the widgets in the aeon skins and would be awesome to see this fixed!
phil65
Retired Team-Kodi Member
Aeon skins do not use this script for widgets anymore.
You have any idea to wich addon this might be related?
It seems to be fixed in the latest build of helix but this could be just a coincidence...
phil65
we can only give tips if you provide the neccessary info. (exact skin version you are using, debug log)
T800
Posting Freak
Can skin widgets be used on a client via upnp?
I'm tempted to move my upnp library to an always on Pi but I use skin widgets for "In Progress" religously and don't want to run without it.
Is this script no longer supported? Because the play function is broken in beta build of Helix. Should I use library.data.provider instead?
Sorry but this is a Kodi problem, not an addon problem.
Can we implement adding favorites from the movies widget? Is that possible now?
