Hitcher
Team-Kodi Member
I don't see why different nodes can't be added that cover these listings and then simply change Confluence to allow the user to select them on the home screen.
Surely it's a win-win situation as there's no extra scripts involved and the user has more choice over what they want listed on the home screen (which, let's face it, is growing more and more popular). Also having more nodes in the core makes using them in other skins easier.
Hell, I'll help code it if need be.
+1 to that
-1 to locking conversations about perfectly reasonable features someone has spent time on implementing after years of people requesting it. Sure you want to do it a better way - but if no one has in several years, at least be a little polite to people that are trying!
Addons I wrote &/or maintain:
OzWeather (Australian BOM weather) | Check Previous Episode | Playback Resumer | Unpause Jumpback | XSqueezeDisplay | (Legacy - XSqueeze & XZen)
Sorry, no help w/out a
*full debug log*.
It's not closing it per se, really, just the way of it. Tone. It's something xbmc/kodi has really struggled with the 6 years or so I have been following it. And it seems of late there's been a lot of sniping etc. again. But I suppose nearing release is a butt load of work so tempers fray a bit, which is also fair enough!
*full debug log*.
Yeah, the way the PR itself was closed right off the bat and the only explanation was basically "no". That gives the feeling of having a door slammed in your face. I wasn't talking about the PR itself having comments turned off for outsiders.
Politeness is not sugar-coating, it is a laxative; it means people will keep giving a shit.
2014-11-18, 11:37
(This post was last modified: 2014-11-18, 11:51 by Martijn.)
Only showing unwatched items is only a few lines in core core and adding the setting.
So why haven't "we" done it? Simply because lack of time or interest or whatever reasons. Create a RP that adds this to core behaviour.
Relying on the script is not the way to go. What happens when I would kill the script for usage in Helix or I***? Then Confluence is cluttered with unused stuff that needs to be ripped out again.
Sorry if it was too blunt to close it but i thought the reason was quite obvious that it wouldn't be added because ronie already said to him it needed be adjusted in core.
(2014-11-18, 11:01)Martijn Wrote: (2014-11-18, 03:07)bossanova808 Wrote: It's not closing it per se, really, just the way of it. Tone. It's something xbmc/kodi has really struggled with the 6 years or so I have been following it. And it seems of late there's been a lot of sniping etc. again. But I suppose nearing release is a butt load of work so tempers fray a bit, which is also fair enough!
Why?
He already knew the answer and the PR would be rejected.
http://forum.kodi.tv/showthread.php?tid=208428
No need to sugar-coat it.
He made that PR with that thread feedback in mind. He didn't already know it would be closed. ronie said there shouldn't be dependencies, so a PR was made that optionally uses the add-on. Then when he asks why, you guys just point him to the same discussion he already had, which doesn't explain why the optional method is being rejected. There's nothing to sugar coat, there has been no reason given at all other than "because I said so".
Whatever. Have fun with that. The rest of us will go and use far better skins. It's just a PITA to tell all the new users why they have to switch skins for basic functionality.
2014-11-18, 22:58
(This post was last modified: 2014-11-18, 22:58 by Ned Scott.)
The stated reason it was closed was to prevent additional add-on dependancies.
tripkip thought it should be configurable in the GUI, so people could have it one way or the other. He made it so that skin widgets isn't a dependency, taking care of the main concern.
ronie thought we should remove unwatched items from core.
Before anything further could be said...
You have decided to close the discussion and make sure that tripkip knew, on no uncertain terms, that his idea would never be considered. You actually went out of your way to give that impression. You didn't even give the PR a second of serious consideration. You wrote him off as just some "dumb user". You would have never done this had it been someone on the team. You wouldn't treat JMarshal or Memphiz like that.
For all I know, the end decision might still have been to not include it, but when you handle it like this then no one else wants to deal with disrespectful "gatekeepers". Then people don't feel like making new features, submitting bug fixes, or even joining the team when invited.
That's a problem.
