Sometimes (most of them, yes) that happens like you said wgstarks.
But it's not the first time that the XBMC seems to like...freeze or something like that when i press 2 3 4 5 6 times.
Which leads me to CTRL ALT DELETE (i have a keyboard attached to the asus EEE BOX in the living room) and terminate the task. BUT, it says nothing is going wrong in the task manager...wierd.
Maybe something got to do with HDMI handshake?
PS: On a side note, does it happens to you guys, Visual C++ RUntime errors here and there?
I do get ocasional C++ runtime errors but only on gotham daily builds and not even running Random Trailers. Just random c++ crash.
Hi kzeleny,
thanks for this great addon.
I have a huge own database with about 1000 movies, so your addon helps me to find the next to see.
Here in germany we have some special characters in movie titles (ä,ö,ü,ß). When your script starts to play one of these movie trailers XBMC crashes and i need to reboot.
Could you add special character support?
Let me know, if you need my support.
Bye
Neospin
Version 1.1.9 now available in official XBMC Repo!
Just pushed a fix version 1.1.10 to official repo should be available soon. You can download from git if you want (see first post)
sorry about that fixed one issue but broke another! All should be good with 1.1.0
I'm trying to modify remote.xml so that there is an equivalent remote key for Q function (like 0).
What's stopping me is, I don't know what the window should be called? Do you have any idea?
2014-02-10, 18:46
(This post was last modified: 2014-02-10, 19:01 by kzeleny.)
in C:\Program Files (x86)\XBMC\system\keymaps\remote.xml map the O button to Queue (Thats the action that I capture) and it should work.
I was only able to test using keyboard.xml I had to add it to the global seciton in C:\Program Files (x86)\XBMC\system\keymaps\keyboard.xml to get it to work.Creating and modifying one in the userdata folder would not work for me.
Ken
Just added new version to my git repo.
Version is now 1.1.11
Added feature to tmdb section to select New DVD Releases (List from Rotten Tomatoes / Flixter)
