2014-07-05, 15:29
(2014-06-03, 00:46)AddonScriptorDE Wrote: v1.1.2:
- Added M3U8 quality selection
- Removed rtmp streaming type
v1.1.3:
- Added M3U8 CDN selection
(2014-03-29, 11:14)Rouzax Wrote: One other thing I've noticed. When I select InfoView in the settings instead of notification it just opens my menu bar as if I press on "Enter" on my keyboard. It should be "i" for info.Yes, from a previous post: "I only found the id for the info view with player controls ('enter'). If anybody knows the id without the controls ('i'), please let me know"...
(2014-04-03, 20:44)Tappy Wrote: How do I get this addon?Install my testing-repo!
(2014-04-09, 23:35)pjam3110 Wrote: This addon is really nice. But i miss the login and the playlist which i added on my computer. Is it possible to do that.You can add your (and any other) playlists by saving the playlist ID in the addons userdata folder. Just have a look at the examples.
(2014-04-29, 17:36)joe1480 Wrote: Is this add-on suppose to work with windows gotham?It should be compatible. I'll have a look at it...
It says incompatible in my list. If it isn't gotham supported, will it be?
(2014-05-10, 12:32)Rouzax Wrote: It appears that that are again some video's that are not shown and skipped.Should be fixed in the latest version.
For example http://www.vevo.com/watch/sia/chandelier...RV81400135 does not load.
(2014-05-13, 20:34)ScottyRads Wrote: One "bug". I launch from the home menu. When I Play VEVO TV (US:Hits) and hit stop (x, esc, backspace) it brings me back to home menu. If I play anything custom it takes me back to the video addons folder once i stop. Anyway to have this jump back to home like the first selection?I don't really know if I can affect this and if it's related to the addon.
The info window should be listed in the following link: http://wiki.xbmc.org/?title=Window_IDs
