vbaros
Junior Member
On my system I noticed that the time stamp of zipped log files is one hour earlier than when they are actually created.
hi,
I'm making progress but stil not there...
I have some question, i used the search tool but could not find an answer.
1- I tried to install a USB stick (bought the sandisk extreme 64gb) but i replaced this line boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 ssh
in the cmdline by boot=/dev/mmcblk0p1 disk=/dev/sda1 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 ssh and it did not work.
I understood that sda1 could be different depending on the systems, buy how do i find the right one?
2- Tried to upgrade to the latest Milhouse build by putting KERNEL, KERNEL.md5, SYSTEM and SYSTEM.md5 in the upgrade folder (wich i had to create) but it did not upgrade, i tried the auto setting, the manual setting without succes. What is the easiest way to upgrade?
NOte: Remember i'm a windows user.
I'm trying to figure out what version to use for judder-free playback of both normal avis and packed bitstream ones.
Official 3.2.4 does play packed bitstream files normal and unpacked bitreamed with judder.
Latest rbej frodo and milhouse gotham builds play packed bitstream files with judder and normal files judder-free.
It all has to do with incorrect timestamps as popcornmix suggested a while back and he proposed a fix to ignore these timestamps. Is there a fix for the official 3.2.4 (preferred solution) or a version that plays both types correctly?
The reason for the prefered solution to work in official 3.2.4 is because I don't want to upgrade databases since I have a mysql setup.
