2014-04-12, 17:23
always on pastebin.com or xbmclogs.com and always FULL logs
(2014-04-12, 11:28)Koying Wrote: This Gotham build should bring you passthrough (to be enabled in audio settings, of course): http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
(2014-04-12, 07:39)jocala Wrote:(2014-04-12, 04:43)elmerohueso Wrote: Weird. The download page says "Uploaded On: 2012-06-27", so I didn't think it'd be the new one.
Nope, you were right, my apologies. I derped out and put up an old link, The OP now points to a fresh copy with 1.0.31.
(2014-04-12, 16:05)thess Wrote: I lost the ability to use directional keys in the user name/password text entry boxes, with any remote including the Amazon remote. Since this is the usual routine I go through when setting up a new build, it stood out. I had to use a mouse-enabled remote. I wonder if it was just a fluke, and if not, if other text entry boxes may be affected.Enable "Remote control sends keyboard presses".
(2014-04-12, 16:05)thess Wrote:(2014-04-12, 11:28)Koying Wrote: This Gotham build should bring you passthrough (to be enabled in audio settings, of course): http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
Quick notes:
--No video problems I can turn up in five minutes
--I do seem to have functional Dolby Digital surround on the first test file I tried (Onkyo receiver, 5.0 config). Using the passthrough config.
However, I noticed that when I was adding a password-protected SMB share, I lost the ability to use directional keys in the user name/password text entry boxes, with any remote including the Amazon remote. Since this is the usual routine I go through when setting up a new build, it stood out. I had to use a mouse-enabled remote. I wonder if it was just a fluke, and if not, if other text entry boxes may be affected.
And of even less importance:
--AirPlay goes back to showing up as an audio device again (rather than no device at all) but still can't stream video to it. (Was this ever working, I wonder?)
--The KeyMap editor add-on doesn't work in this build or the last build I was on (the last recommended SPMC build). In SPMC it gave a 'main.py' error, in this build it says Error Script Failed: Keymap Editor.
(2014-04-12, 07:37)dismantler Wrote:Thank you very much for the reply. I'll see how annoying it is, but now I know that Gotham will fix my issue.(2014-04-12, 07:26)Natedawg87 Wrote: Hello. My Fire TV just arrived today. I have been following this thread since the beginning, and I have installed SPMC 12.4.2 and things seem good so far. I know earlier in the thread, somebody mentioned Shift and Caps Lock not working on a USB keyboard. I found the same was true for me. I did a search of this thread, but I couldn't find an answer. Has a fix for this been found? Not a huge deal, since it won't be too often where I have to use these keys.
I have the Logitech K400 keyboard, and the Shift and Caps Lock keys work in the main Fire OS.
Thanks for all the hard work on this!
XBMC Gotham has full support for keyboards in Android. Unfortunately Frodo didn't get that going in time.
(2014-04-12, 18:02)haikuginger Wrote:(2014-04-12, 17:57)alucard77 Wrote: Sorry for the dumb question, but does Fire TV support AG Wireless? I am thinking only N, but wanted to confirm
Looks like it supports 802.11a/b/g/n.
(2014-04-12, 18:09)alucard77 Wrote:(2014-04-12, 18:02)haikuginger Wrote:(2014-04-12, 17:57)alucard77 Wrote: Sorry for the dumb question, but does Fire TV support AG Wireless? I am thinking only N, but wanted to confirm
Nice!
Anyone try it with AG to see what speeds it yields. I have been meaning to upgrade to a wireless AG for a while now, but none of these boxes supported it. I know my 1080P encodes sometimes push the Wireless N I have in my house.
