Has anyone using AFTV relocated their /userdata/thubmnails folder to a remote location(SMB, NFS, etc) successfully using advancedsettings.xml, and if so has it affected performance of the UI at all. I would like to do this if it is possible.
roveer
Senior Member
Can anyone recommend an skin for XBMC on AFTV that gives a more modern (not as in contemporary) look? GUI's have evolved as of 2014 they have a much newer more refined look. Love my confluence because I know my way around, but would love to take a look at somthing that blows my doors off now that I have a box powerful enough to run them on. Have always stayed away from skins because most of my hardware was never good enough to run anything that required power. Thanks.
Roveer
nbox does look nice... is it fairly lightweight? Also, which version do you recommend? The original or one of the mods?
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
syk69
Junior Member
I've noticed that on Gotham builds (both latest nightly and specific fire TV build from koying) when I choose a Dolby digital video there is always a loud static pop at start of loading movie. No such issue with DTS movies. I have pass through enabled. And only libstagefright on. Is this a known issue on android?
FLIRC trnslates IR to keyboard signals so it works on all those devices that recognize keyboard presses, is my understanding.
I connected flirc to the usb port on my samsung TV and it recognized it as a wireless keyboard. and I was able to send commands through the remote. I do not doubt you could do something similar with FTV.
