2015-03-03, 13:53
Thx for your response.
I will try it next wekkend with a fresh SteamOS installation and give you a feedback.
(2015-02-28, 22:30)ProfessorKaos64 Wrote:(2015-02-18, 15:20)wsnipex Wrote: what happens if you do apt-get dist-upgrade?
I have done that, no effect. I still get unmet dependencies when trying to install xbmc or kodi. Kodi will look for kodi.bin, and attempting to install xbmc, results in dependency failure from kodi.
Package: *
Pin: origin mirrors.xbmc.org
Pin-Priority: 800
Package: *
Pin: release l=SteamOS
Pin-Priority: 900
Package: *
Pin: release l=Debian
Pin-Priority: -10
The following packages have unmet dependencies:
kodi-bin : Depends: libva-x11-1 (> 1.3.0~) but 1.0.15-4 is to be installed
Depends: libva1 (> 1.3.0~) but 1.0.15-4 is to be installed
E: Unable to correct problems, you have held broken packages.
Package: *
Pin-Priority: 800
Package: *
Pin-Priority: 900
Package: *
Pin-Priority: -10
Package: libva-x11-1
Pin-Priority: 900
Package: libva1
Pin-Priority: 900
(2015-04-04, 10:18)mbarreira43 Wrote: hello maybe someone can help me just bought the kodicast installed on my e-pad had already chromecast and allcast installed prior to this and once i got it all programmed nothing is streaming on the TV still playing on e-pad ....
(2015-04-04, 09:46)wsnipex Wrote: apt-cache policy libtag1c2a kodi
version 1.9 should be available in our repo. Maybe SteamOS changed something or you have some other package that hard-depends on that ancient 1.7 version.
