Did some more tests. Connected to another Sony TV directly 3D works. If I connect to the same TV through my Onkyo NR737 3d doesn't work anymore. HD audio is fine.
2014-12-17, 12:38
(This post was last modified: 2014-12-17, 12:47 by Caramba69.)
It really sounds like a HDMI handshake and EDID issue. I have ordered an EDID Manager to see if this will solve the problem.
If so, that may be an easier fix Caramba69? Vs. HDCP issues I'm guessing. Please let us know after you receive and test.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
stewfo
Junior Member
"We are here just guessing it is the compatible issue, maybe it has other reasons and we are also collecting information in order to solve this problem."
Not really an answer, are you saying that you don't know what the issue is?
All I want is what was advertised (HD Audio) or at least an answer that explains what it is Vidon is doing to resolve the issue.
"collecting Information" !!
Wolly
Since you guys just fixed the most important issue (Buffering) and most of us has had VidOn box for a month.
Do we get an extra month on our membership?
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
2014-12-17, 20:39
(This post was last modified: 2014-12-17, 20:44 by cmdr.adama.)
Even 1080p24 works good there are still droped frames. It is getting worse with higher frequencies. If I play 25Hz movies they sometimes don't stutter at the beginning but stutter after some chapter skips. I also saw movies with these frame rate which are stuttering right from the beginning and the audio is asynchron to the picture after some chapter skips. The worst problem occurs for 29.97 Hz movies. They don't play at all without stuttering. There is also stuttering for 24p directly after chapter skip. Wolly, when can Vidon solve all these problems? Can you solve them by your own or do you need a SDK update by Allwinner?
stewfo
Junior Member
2014-12-18, 00:08
(This post was last modified: 2014-12-18, 11:47 by stewfo.)
Thanks for explaining
"What I mean is that not every reported "handshake" issue is the real handshake issue, some are and some are not.
Before we get more information, your issue can not absolutely be definded as a handshake issue."
Wolly, what can I do to help you get more information about my potential handshake issue.
let me know
