2014-11-09, 13:04
After written several iOS apps including an XBMC remote control called Consilium B: XBMC remote, I wanted to start a new project again focussed on Kodi.
So, I started again and after a few months I have the following:
Since version 1.2 a Pro version is available which adds the following features:
- Progress: keep track of your series. See in an instance your last watched episode and the next one to watch.
- History: this option gives you a calendar overview of the movies and episodes you have watched and when exactly.
- Customizable top menu bar: choose which buttons and the order you want.
- More advanced remote control views: Different views are available and you can customize your own user command menu with over 175 Kodi commands.
- A more detailed dashboard (popular movies, series, actors, birthdays, box office numbers, movie news and more).
- TV Tunes support - use the add-on TVTunes to download the series tunes and Kodi Control Center will play the theme when the series is selected.
- Search in Kodi: search for movies, series, episodes, actors, etc. in your database.
- Cinema Experience support: start your movie with this great experience.
- Library Management - edit/delete items in your library.
- Offline caching - when enabled Kodi Control Center will store the returned Kodi/XBMC information and use it when offline.
- Caching: enable the possibility to cache data (not for all options available).
- Trakt support - login your Trakt account and see your Trakt library in Kodi Control Center. You have the possibility to change the status (watched/in collection/watchlist), manage lists (create/delete/edit), add items to your lists, see your personal calendar, trending movies/series and more.
Here some screenshots from the Pro version:
I hope everyone knows that an App really takes a lot of time and has thousands lines of code. I am also human, so there could be some bugs. Don't immediately write a negative review on the App Store. Please use the e-mail option within the App or use this forum.
If you like the app, I would appreciate a positive review on the App Store and of course a Facebook page like. Go to Facebook.com/KodiControlCenter.
Get Kodi Control Center now! It's all free! Use the following link:
Kodi Control Center for iPad
