It's possible to made update for http command : if i use url scheme for example open another apps in kodi cc, actually not work.
My exemple: http command = roomie://
This http command work in safari, but not work with http command in KodiCC
For finish for the name for http command, it's possible change the name in buttons "http command" by the name of reel http? Exemple: for me, the good name for the Button is Roomie.
Hi Richard great job on the new release. Had a quick play and loving the new power menu and button layouts. The gfx I did for that really shines when you can actually use it. Great work on the programming.
I have not had to much time with it but will fully test it over the next couple of days to see how it works out.
Let me know when you want to test the touch side of it
After several hours spent with the new version of KODICC, it's a real pleasure to be able to configure the buttons that you want at the top and bottom of the application. Hopefully in the next version we can do the same with the remote control (Touch Version)
