2015-09-21, 18:40
this is what it should look like
take no notice of the audio track window its the off subtitle part that you need to look at this should be at the top at all times, you can see the smaller line for the info bar. I sent you the image for that ages ago but you have not used it,
I just think it looks more spaced out
the buttons at the top need to be highlighted like the in my images and the same for the buttons at the bottom when in use and the text goes white when selected, you can see this at the top of my image with the time icon
