2014-11-29, 08:00
(This post was last modified: 2014-11-29, 08:03 by wrxtasy.)
Unfortunately fritsch still only UK, EU and USA power pins - what about the rest of the planet ?
Once you add another adapter to the end on those plugs on the power brick the whole setup becomes shonky and very likely to disconnect power as it falls off the wall.
If this is the case Sam should consider not even shipping a power supply for some users and reducing his price point.
Actually, since that's New IT's site, it probably comes with the same kind of multinational power adapter that their other products come with, which is the interchangeable clip. Their default set has UK, EU, US, and AU/NZ plugs, but you can get others that fit the clip. I don't know this for sure, but for things I could actually find pictures for, they all had the clips on them.
I assume it also depends on what regional shop you buy from. I got a CuBox-i2ex from newegg, and it only has a US plug, but it was sold from a US site.
fritsch
Team-Kodi Developer
Yeah, i don't think the powersupply is the selling point. Sam has made a decision, It's his product. When he wants to add a pack of gummibears that's also fine :-)
It will help that cubox gets better and even better linux support for the whole planet.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
