Milhouse
Retired Team-Kodi Member
No new build today - network/routing problems with BT (my ISP) mean it's impossible to reliably download (from git/github) or upload (to ftp server). Not sure when the problem will be resolved as BT are yet to accept there is even a problem despite multiple reports from users nationwide throughout the day. Ho hum.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Thanks for keeping thing going popcornmix! Those latest firmware changes look nice.
What is the overclock recommendation for 1080i60 playback using advance deinterlacing at this point? I've been using gpu_freq=300 with success, but every now and then a news ticker will get jittery. It gets even more so when I bring up the playback information overlay to see if it is skipping frames.
Also, for using advanced deinterlacing, what are the recommended settings for "adjust display refresh rate to match video" (mine is on) and "sync playback to display" (mine is on and using method resample audio) ?
I just tested many movies on RPi1 and 2 (MP4/DVD/ISO/PAL/24p/25p) after "The "prefer pts" option is gone."
And all content play's super smooth via OMX=on and MMAL=off and No overclocking here.
Great ! Thanks popcornmix and Milhouse for all your works.
hi,
with the build #0729-gc37b5a7 my first RPi2 with hifiberryDACplus hang-off (freeze) with videoAddons (MTV.de).
Not able to handle this hardwired network rpi2. (fresh install)
The second rpi2 on my LCD TV over HDMI makes this Job better, but stops on playing between two Videos with this build
...switch back to #0721 and all work fine on both RPi2.
(OT)
Have any people testet here Windows 10pro?
I'm not able ( and also other people in the net) to share files on this System over smb - after 2 days a click on my Win7pro backup and all's right with the world.
Windowsdisaster²
will the "advanced deinterlacing" (which is *fantastic* by the way) also be included in the openelec isengard release?
Thanks,
Max
