Every once in a while, I get a tiny droupout (gap) in the audio. Is this likely from limiting the hdmi_clock AND using Adjust PLL together? In case it matters, I don't use the Adjust Display Refresh Rate setting because that causes a lot of resyncing to occur with my AVR and projector.
Experience: It's what you get when you were expecting something else.
Small niggle with 0817, bcmstat.sh doesn't seem to work:
rpi:~ # bcmstat.sh
-sh: bcmstat.sh: Permission denied
/usr/bin/bcmstat.sh is zero bytes.
Milhouse
Retired Team-Kodi Member
Yep, sorry about that - it's 0 bytes in both the Pi1 and Pi2 builds, there must have been a temporary glitch with github.com during the build. Should be OK tonight.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
2015-08-19, 01:34
(This post was last modified: 2015-08-19, 01:36 by f1vefour.)
Why are the 16.x builds so much slower to boot? It's like they are waiting for something, nothing wrong just booting slow.
Both on P1 and 2.
