2015-10-14, 22:01
(2015-10-13, 23:49)Milhouse Wrote: [*]Exclude [env] kodi-999.51-nonX11-mousewheel-support.patch: Merged upstream
Any chance the mousewheel support will get retrofitted into stable 15.x ?
(2015-10-14, 20:53)popcornmix Wrote: @woronczak @hdmkv
Can you try this test firmware:
https://dl.dropboxusercontent.com/u/3669...e_hdmi.zip
Use start_x.elf and fixup_x.dat and replace start.elf and fixup.dat on your sdcard. By default there will be no change, but can you try with config.txt option:
Code:hdmi_debug=0xffff
(2015-10-14, 22:21)hdmkv Wrote: @popcornmix, just making sure I should replace start.elf and fixup.dat on my Pi's SD card with your start_x.elf and fixup_x.dat? And, just rename them? Or, are you saying rename the start.elf and fixup.dat on my SD card, then copy over your start.elf and fixup.dat?
In my config, I have a hdmi_ignore_cec_init=1. Leave that alone and add hdmi_debug=0xffff?
(2015-10-14, 12:28)popcornmix Wrote:(2015-10-14, 12:12)woronczak Wrote: Disconnecting and then reconnecting the HDMI cable = functions normally (so GUI is NOT displayed in frame-packing garble).
Output = 148352000 in 3d FP mode. 74176000 in the GUI which is stuck in frame packing
Okay, that suggest when you are seeing corrupt GUI we are outputting a valid 2D signal, but the display has not reacted to the change.
What is make and model of display. Is there any way of updating firmware?
If you have a receiver connected, is it any different if that is bypassed?
Do you only get this for frame-packing, or do you also get this with "Use Full HD HDMI modes for 3D" disabled (i.e. switching from 3D SBS to 2D).
# uname -a
Linux rpi512 4.1.10 #1 Wed Oct 14 22:02:21 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 11 2015 16:21:59
Copyright (c) 2012 Broadcom
version cdea693c2a4280e4855643dc7840392d915f19b8 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151014215123-#1014-gf4c0e29 [Build #1014]
# vcdbg log msg 2>&1 | grep DTOK
001719.338: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
(2015-10-15, 00:02)woronczak Wrote: Actually it does it when Use Full HD HDMI modes for 3d is off as well (although I'm pretty certain I remember that it didn't happen for SBS movies with earlier versions of OpenELEC a long time ago)
(2015-10-14, 23:27)popcornmix Wrote:Using Epson 5025UB and build #1012, and UI switched back to 1080p/60.00 (from my temporary 1080p/50.00 fix from woronczak)...(2015-10-14, 22:21)hdmkv Wrote: @popcornmix, just making sure I should replace start.elf and fixup.dat on my Pi's SD card with your start_x.elf and fixup_x.dat? And, just rename them? Or, are you saying rename the start.elf and fixup.dat on my SD card, then copy over your start.elf and fixup.dat?
Yes, leave whatever is in your config.txt, and add the new line.
You want to rename start_x.elf from zip file to start.elf and overwrite the start.elf on your sdcard (similarly for fixup_x.dat).
(2015-10-14, 14:14)illiac4 Wrote: Milhouse can you please build later tonight tvheadend server addon for rpi2 from latest git because some changes has been made to support m3u for iptv and would like to test it to report any possible bugs. TNX
(2015-10-15, 00:29)hdmkv Wrote: Not sure if it'll help, but let me take a video (with my standard config.txt) and UI at 1080p/60.00 and show what's happening. And, will do same with woronczak's 1080p/50.00 trick. I'll post this shortly.
(2015-10-15, 03:35)hdmkv Wrote:(2015-10-15, 00:29)hdmkv Wrote: Not sure if it'll help, but let me take a video (with my standard config.txt) and UI at 1080p/60.00 and show what's happening. And, will do same with woronczak's 1080p/50.00 trick. I'll post this shortly.
