2016-03-04, 21:59
yes, black screen prob is history. thanks!
(2016-03-04, 21:20)_Spook_ Wrote:(2016-03-04, 20:23)fritsch Wrote: Uploading new build ... this service.xbmc.versioncheck seems very stubborn :-)
All good. No more black screen. Thanks Will do some soundchecks now to see if passthrough audio works on my miniDP1.2->HDMI 2.0 adapter again
EDIT: Still no go on passthrough audio when using the adapter. No biggie. The new skin takes some getting used to
(2016-03-04, 16:14)n2vwz Wrote: I loaded the latest Milhouse KODI 17 build (#0226, 26-Feb-2016) ... I did notice, however that the OpenELEC settings menu is missing from the SYSTEM top level menu. Is this a permanent condition in consideration that this is test software?
(2016-03-04, 23:04)fritsch Wrote:(2016-03-04, 21:20)_Spook_ Wrote:(2016-03-04, 20:23)fritsch Wrote: Uploading new build ... this service.xbmc.versioncheck seems very stubborn :-)
I still have no idea which adapter you use, but hey: if that thingy breaks passthrough - throw it :-)
(2016-03-05, 00:17)fritsch Wrote: Yeah - has nothing to do with us ...
Quote:Section "Device"
Identifier "Device0"
Driver "intel"
VendorName "INTEL Corporation"
Option "TripleBuffer" "false"
Option "TearFree" "false"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "HDMI1"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1920x1080@50p" "[email protected]" "1920x1080@23p" "1920x1080@24p" "1920x1080@60p"
EndSubSection
EndSection
Section "Monitor"
Identifier "HDMI1"
HorizSync 14.0 - 70.0
VertRefresh 24.0 - 62.0
Option "PreferredMode" "1920x1080@50p"
# Option "DPMS" "true"
Modeline "1920x1080@23p" 74.176 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Modeline "1920x1080@24p" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Modeline "1920x1080@50p" 148.500 1920 2448 2492 2640 1080 1084 1094 1125 +hsync +vsync
Modeline "[email protected]" 148.352 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Modeline "1920x1080@60p" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
EndSection
Section "Extensions"
# fixes tearing
Option "Composite" "Disable"
EndSection
(2016-02-28, 09:10)fritsch Wrote: Jep @wsnipex that's the case - I installed 16.04 on a braswell two days ago. Only difference, one needs to install the xserver-xorg-legacy packages and reconfigure that instead of x11-common. Also wsnipex vaapi ppa is not needed anymore. For kodi one could also install the kodi nightly ppa.
(2016-03-06, 01:02)Markus_23 Wrote:It depends on the others. So just add it.(2016-02-28, 09:10)fritsch Wrote: Jep @wsnipex that's the case - I installed 16.04 on a braswell two days ago. Only difference, one needs to install the xserver-xorg-legacy packages and reconfigure that instead of x11-common. Also wsnipex vaapi ppa is not needed anymore. For kodi one could also install the kodi nightly ppa.
Tried a xenial server nightly.
Do i have to install the mentioned 'xserver-xorg-legacy' package additionally or instead of a/some package(s) you stated in your first post ?
