2015-08-28, 01:17
Thank you for your help
just installed Ubuntu 14.04.3 LTS as a dual boot on a win 7 machine (64 bit)
AMD E-350 Processor × 2
Gallium 0.4 on AMD PALM
then installed the latest Kodi (15.1 Git:d496682)
most addons do not work. others do work
it starts goes to 50% and disappears with no error, except check log in bottom right.
errors i get in log and warning (fullll log below)
ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:43, error_code:5, request_code:18 minor_code:0
17:34:30 T:140478253189056 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
17:34:30 T:140478253189056 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
17:34:31 T:140478253189056 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
17:34:31 T:140478253189056 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:34:51 T:140478253189056 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:34:51 T:140476359198464 ERROR: Unable to load librtmp.so.1, reason: librtmp.so.1: cannot open shared object file: No such file or directory
17:34:51 T:140476359198464 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://fml.BC83.systemcdn.net/20BC83/tv/mp4:14.low.stream.mp4?6fb0914a89a1db80524b1cf2e1eec54a5a71fbf5f1464dbdaa5d5959e8e342687ee4face21c463a6d0870e9181753059d17865e3bbb6857c161fed954324b1498b1655a37d78155f8f3136 playpath=mp4:14.high.stream.mp4?6fb0914a89a1db80524b1cf2e1eec54a5a71fbf5f1464dbdaa5d5959e8e342687ee4face21c463a6d0870e9181753059d17865e3bbb6857c161fed954324b1498b1655a37d78155f8f3136 swfUrl=http://www.filmon.com/tv/modules/FilmOnTV/files/flashapp/filmon/FilmonPlayer.swf tcUrl=rtmp://fml.BC83.systemcdn.net/20BC83/tv/mp4:14.low.stream.mp4?6fb0914a89a1db80524b1cf2e1eec54a5a71fbf5f1464dbdaa5d5959e8e342687ee4face21c463a6d0870e9181753059d17865e3bbb6857c161fed954324b1498b1655a37d78155f8f3136 pageUrl=http://www.filmon.com/ live=1 timeout=45 swfVfy=1]
17:34:51 T:140476359198464 NOTICE: CDVDPlayer::OnExit()
17:34:51 T:140476409456384 WARNING: Attempt to use invalid handle -1
log following
http://goo.gl/I3XOTo
log following
