  • 135
  • 136
  • 137(current)
  • 138
  • 139
  • 146
  Thread Closed
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-04-06, 06:25)3DBuff Wrote: I noticed after today's update that "Audio offset" is not working. The adjustment works I can change the numbers or move the slider but it has no effect on audio delay during the playback. I really make use of it when using small multi channel headphone amp. rather then full blown receiver for headphones.
Can you check if it works with omxplayer enabled/disabled?
(2016-04-06, 12:18)Milhouse Wrote: Alarm clock - I think it's Leopolds dev update addon, it will check for a new version every 3 hours.
Yep - seems you are right..
(2016-04-06, 12:18)Milhouse Wrote: For the one hour problem, have you tried a stock/clean system - no add-ons, only Estuary skin... At least it might help narrow down if this is add-on/skin related, or a core issue.
To an extend... But could do more (with logging)... But find it so odd that I am not able to find a reason from reading the logs...
Will try an "all clean", and test...
Just tested with renamed .kodi - I enabled ssh, samba and tvheadend - rebooted and waited 1 hour....
And the result is the same! Kodi util goes up from 2-3% to fluctuating btw. 5% and 30%+ (I suspect it will increase further with time)...Not a single extra add-on installed....
Are nobody else seeing this?? Perhaps not as grave as me, but some increase in cpu utilization after 1 hour?? One diffs. compared to what you have is perhaps running on RPI2 and from an USB drive (that is faster than ANY SD I have ever tested).. And using LibCEC..
Would like to see bcmstat.sh px from others, after 1 hour...
(2016-04-06, 20:55)toppot Wrote: Just tested with renamed .kodi - I enabled ssh, samba and tvheadend - rebooted and waited 1 hour....
Could you try again without tvheadend?
After the girlfriends done watching Big GrinBig GrinBig Grin
Girlfriend->S<-?! :-O
(2016-04-06, 22:24)nexusle Wrote: Girlfriend->S<-?! :-O
Suppose it could be either autocorrect or a Freudian Slip......
Loaded back latest #0405
OMXplayer - Audio Offset is working OK
MML - Audio Offset is stuck in 0 delay. Controls have no effect on audio delay.
It started with build #0404
New OpenELEC.tv Krypton build #0406: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.6 #1 Wed Apr 6 21:06:02 BST 2016 armv6l GNU/Linux
# vcgencmd version
Apr  6 2016 18:42:46
Copyright (c) 2012 Broadcom
version b7da52ec944a9e1691745036966b3b2a48b19e8b (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160406210510-#0406-g0026734 [Build #0406]
# vcdbg log msg 2>&1 | grep DTOK
002466.319: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC.tv master (0026734b, changelog) and tip of XBMC master (2d8f68ca, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest bcm2835-driver master (0a96f63b, ahead +13)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (3c26ce1e, ahead +13)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (5cf12e83, +7), adsp.biquad.filters (af575f3d, +7), adsp.freesurround (6dc533be, +8), asplib (da66f517, +13), inputstream.mpd (6bd24f3f), peripheral.joystick (76b7c40a, +48), pvr.argustv (974820ab, +25), pvr.demo (e74822f2, +21), pvr.dvblink (82c7b4d5, +20), pvr.dvbviewer (6ab861fa, +33), pvr.filmon (0d8dd5bd, +27), pvr.hdhomerun (fd9daf4a, +32), pvr.hts (0f88a357, +67), pvr.iptvsimple (b741cac7, +27), pvr.mediaportal.tvserver (96f415e3, +52), pvr.mythtv (f8d25fda, +36), pvr.nextpvr (d445c5ad, +27), pvr.njoy (b9b0ae43, +19), pvr.pctv (f1880484, +25), pvr.stalker (14a7c70d, +28), pvr.vbox (e70146d8, +27), pvr.vdr.vnsi (b64e7b4c, +43), pvr.vuplus (d8c6f9ba, +23), pvr.wmc (898e2dad, +33)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Exclude [env] kodi-999.42-KEY_EPG.patch: Added upstream
  • Exclude [env] package.mk: dcadec: Drop (not needed anymore)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 6be9ebe7: libva / libva-driver-intel: bump to 1.7.0
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 20965d0a: mesa: update to 11.2.0-rc4
  • Include [env] patch: xf86-video-intel: bump to 3fafabe
  • Include [env] patch: Clean Kodi view cache on startup
  • Include [env] patch: Fix OE settings button after Estuary update
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Add support for dynamic device tree overlays
  • Include [env] patch: Set default volume steps to 20
  • Include [env] patch: Enable game controllers in manifest, add repository.kodi.game
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
  • Include [env] patch: Update inputstream.mpd settings
  • Include [env] patch: Install dtoverlay userland
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Binary-Addons: Package inputstream.mpd
  • Include [env] patch: kodi: peripheral.joystick binary addon
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8723: Implement filecache retry logic
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9334: [chg] decrease volume steps to 20
  • Include [pkg] PR:9538: [Peripherals] m_bNeedsPolling broken for busses where it is set outsi?
  • Revert [pkg] e9a6d59f: VideoPlayer: inputstream, fix cp error (Reason: inputstream.mpd needs update) (kodi)
  • Revert [pkg] PR:9531: VideoPlayer: add method for requesting desired video resolution to demuxer (Reason: inputstream.mpd needs update)
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. New firmware
  3. [addons] change db version 21 update to set system addons to disable
Build Details:
  1. Firmware (Apr 6):
    • firmware: arm_loader: Strip comments after dtoverlay and dtparam. See: link
    • firmware: dtoverlay: Allow aliases to be used with target-path.
    • firmware: dtoverlay: Support disabled (__dormant__) fragments.
    • firmware: dtoverlay: Multiple overlay instances.
    • firmware: host_applications: Add dtmerge application. See: link
    • firmware: clock: Make clock logging less spammy. Can be enabled by host
    • firmware: config: Remove unsupported config options
    • firmware: Fix typos in comments. See: link
    • firmware: hello_video: Remove the timout, to avoid the application quits before the ending of some videos. See: link
  2. XBMC:
    • [Estouchy] change include syntax (PR:9562, 1 commit, 1 file changed)
    • [cmake] Fix passing CMAKE_BUILD_TYPE in FindFFMPEG (PR:9563, 1 commit, 1 file changed)
    • [addons] change db version 21 update to set system addons to disable (PR:9546, 1 commit, 1 file changed)
    • [win32] Cleanup project files after libmpeg2 removal. (PR:9564, 1 commit, 2 files changed)
    • add support for external PGS/.sup subtitles (PR:9559, 1 commit, 4 files changed)
    • fix for PR #9559 (PR:9566, 1 commit, 1 file changed)
    • [cmake] Speed up export-files target (PR:9561, 1 commit, 1 file changed)
  3. newclock5:
    • New commits in this build:
      • rendering: skipping gui rednering should be independent from dirty (60fbf12e)
      • VideoPlayer: move setting videoDelay from player to renderer (0d1b2eba)
      • VideoPlayer: only check skipping if we render a frame, saves CPU (72d0c45c)
      • squash skip (b2653c8b)
  4. kernel 4.4.y:
      • Revert "bcm2835-dma: Fix dreq not set for slave transfers" (ccb9ab7b)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Same result - 1 hour in idle, and the same picture....
And a strange experience: I moved .kode and rebooted, then I made the install through the short guide. I selected Samba and SSH - but that did not stick, and I had to use the "Libreelec" menu to enable those - perhaps something to look in toHuh
But the real strange thing - after I removed this .kodi folder, and moved the old .kodi back I had most of my settings intact. But only MOST of them. My sound (7.1 channels) settings where gone, also CEC settings, playback acceleration and weather... But it seems everything else is in place, including screen calibration etc...(or perhaps not - I think I have 1:1 and therefore no calibration).. But language (or perhaps that came from setting it during the guide after the first removal)...
(UPD: Seems services where also reset back to defaults - I had disabled airplay, avahi etc. earlier - and they where also reenabled..)
Is something stored outside of .kodiHuh??
This is not the biggest issue - the biggest one is still this "1 hour problem".....
(2016-04-07, 08:16)toppot Wrote: then I made the install through the short guide. I selected Samba and SSH - but that did not stick, and I had to use the "Libreelec" menu to enable those - perhaps something to look in toHuh
Which "short guide"? Edit: Presumably you mean the "First Run Wizard"?
If you are using my LibreELEC builds and having problems it would be best not to report them here as this is the OpenELEC thread. The LibreELEC builds should still be considered experimental and are (for now) unsupported which is why I'm not yet documenting them with their own thread, although they should - in general - work to the same standard as these OpenELEC builds. I appreciate you using them, but I'm not yet in a position to support them so please continue reporting issues only about the OpenELEC builds in this thread.
(2016-04-07, 08:16)toppot Wrote: Is something stored outside of .kodiHuh??
No, Kodi settings are all stored within .kodi. The only settings outside of .kodi are OpenELEC settings (eg. network config, ssh, samba etc.)
(2016-04-07, 03:23)3DBuff Wrote: Loaded back latest #0405
I tested this yesterday (for the purpose of correcting audio delay when using bluetooth headphones) and I can confirm this behavior 100%.
Kind regards, Frank
Kodi: LibreELEC Beta
HTPC: Raspberry Pi 2 (Model B)
TV: Toshiba 47"
NAS: Debian Jessie x64 (Gigabyte GA-D510UD), HDD 3x1.5 TB + 1x2 TB (SnapRAID, MergerFS)
Try with #406.
Yes indeed - the "First Run Wizard"... But my point was, that it was perhaps a small bug that enabling SSH and Samba in the wizard did not stick... Just FYI..
(2016-04-07, 09:04)Milhouse Wrote: If you are using my LibreELEC builds and having problems it would be best not to report them here as this is the OpenELEC thread. The LibreELEC builds should still be considered experimental and are (for now) unsupported which is why I'm not yet documenting them with their own thread, although they should - in general - work to the same standard as these OpenELEC builds. I appreciate you using them, but I'm not yet in a position to support them so please continue reporting issues only about the OpenELEC builds in this thread.
This problem startet when I was still on OpenELEC... Your version 3xx (believe all the way back from 319, perhaps even sooner)
Can you explain how I then can restore my .kodi, have all my add-ons etc., but the config reset to default... Quite strange.. HuhHuh
Hopefully someone can help with this one. I am using TVHeadend as a backend for my Live TV. I have one RPi1 providing this service. The TV signal is fed to the Pi using a HDHomeRun device (should be evident from the logs provided). This RPi1 is running OpenELEC 6.0.3 and the tvheadend addon service from the unofficial repository (build according to the TVHeadend config page is 4.0.8 ~ OpenELEC Tvh-addon v6.0.4)
I use the pvr.hts addon on RPi2 devices around the house to be able to watch TV. I have noticed that on occasion, whilst watching Freeview HD channels, that audio seems to drop. I've managed to capture a log of this scenario and am just wondering if this is the fault of the backend, a problem with pvr.hts or maybe even a problem with decoding the streams.
I currently use build #0406 and an in anticipation of this happening again I turned on debugging (including the video component - well I hope I did as I did it from the advancedsettings.xml so as not to get the overlay text on screen).
Kodi Log: http://sprunge.us/aBiD
TVHeadend Log: http://sprunge.us/AASY
The loss of audio seemed to happen at around 15:35:20 but I have provided full logs just in case there is a cumulative problem that may have caused it.
Any help would be much appreciated.
Thanks in advance.
  • 135
  • 136
  • 137(current)
  • 138
  • 139
  • 146
  Thread Closed
  • 6 Vote(s) - 5 Average
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)56
