2017-08-09, 21:23
You do not need VPN. Why would you? Are you intending to do something illegal on your C2?
(2017-08-09, 20:30)etrin Wrote: I just ordered an ODROID C2 after reading all the comments here.VPN are not needed normally for local home networked streaming or even streaming from within a persons own country.
I wanted to ask one thing about the LibreELEC Jarvis for the 2160p 10bit HEVC AMLogic S905 ODROID C2
All I am hearing is VPN you have to have VPN on your kodi box.
Does this support the vpn built into kodi ?
I also have a pureVPN account and found out I can put it on 5 devices...will it work on the ODROID with this os?
(2017-08-09, 10:08)rondog9 Wrote: Thanks wrxtasy.
Yeah I didn't want to do everything with 1 box just doesn't make sense to me..
Just the last thing is Raspberry Pi3 going to do the job well considering it only has 1gb ram? Also with the 1gb ram on it how futureproof is it with running on libreelec on it.. I know newer libreelec/ kodi would require extra ram? Can you upgrade the ram on raspberry Pi 3 in the future? Or what is the option that I have?
Thank you and sorry for the confusing questions.. The posts doesn't answer these questions so
I am asking here..
(2017-08-09, 10:23)marko-mb Wrote: What I want:
- kodi, and option to install google play apps (I will use a TV stream app from out CABLE supplier that requires unrooted system. app: "D3GO")
- android, stable system and stable playback without freezing etc...
- 1080 HD
- digital audio output for my receiver (probably spdif coax (only free left )
- option to power on and off with IR command (harmony remote) with only one command ! not through menus etc....
- LAN - to stream mkv files x265 and x264 from my NAS
- airmouse and keyb for some youtube and extra apps
- not a must but would be cool: a controller option or option to use smartphone to play and control some games for kids)
thanks!
Quote:(At the time writing this I am using lenovo q180 .. now installed openelec because I had more and more problems with windows in 2 years of use, now openelec keeps freezing. movies showing titles that are no longer on disk, sometimer IR power on and off works sometimes not, so it is time to get rid of it!)
(2017-08-10, 09:36)biochem Wrote: What do you mean with not capable of auto resolution switch? How does this appear in everyday usage? I am not able to start movie A (1080p) and after that movie B (2160p) without having to change something in the settings?That is exactly what I'm saying - Android is not capable of 1080p/2160p Auto resolution switching.
(2017-08-10, 10:30)wrxtasy Wrote: Why do you need Android for 4K Kodi only anyway - you are only handcuffing yourself IMHO ?
(2017-08-10, 20:58)biochem Wrote:Personally if you just want 4K HDR Netflix and Prime I would buy a modern 4K TV with those exact Apps already running on the TV. All video upscaling, and correct color space outputs are taken care of by the TV automatically then.(2017-08-10, 10:30)wrxtasy Wrote: Why do you need Android for 4K Kodi only anyway - you are only handcuffing yourself IMHO ?
Thanks for opening my eyes. This is getting complicated.
Right now I am thinking of a two device solution.
Device 1: Kodi
- 4K and 1080p movies on NAS → on a 4K Television
- fully compatible to HEVC, HDR10 and all audio HD formats (DD+ works as well?)
- CEC (I hate multiple remotes)
- a fine working resolution switch
→ Odroid C2 with Libreelec?
Device 2: Netflix, Prime in 4K
- just for streaming Netflix, Prime and two a local media libraries in my country (as this work perfectly with the 2nd Gen Fire TV Stick - but no 4K support)
→ Fire TV 2 Box?
Does this make any sense?
