[MOD] Aeon MQ 6 - Krypton by Angelinas
#31
(2016-03-30, 12:35)Angelinas Wrote: I didnt start to change for Krypton, this thread isnt mine....Krypton version will be 1080i ...I dont want to change for krypton, lot of my changing code depend of script helper..
This script doesent work for Krypton version.
@Angelinas
Need Help!!!Angel
I got most of the skin working the only that is not working are the OSD particularly VIDEO/AUDIO OSD
Please!!!!!!!!!!!!!
MY CURRENT MEDIA PLAYER | MY HOME THEATER
MINIX NEO U9-H LIBREELEC v18 Leia | EGREAT A10 | NVIDIA SHIELD | SAMSUNG QLED QN75Q7 | Sony 43 Android TV HDR
XBOX ONE X UHD BLU-RAY | PS4 PRO 4K w/PSVR | NAKAMICHI PRO 7.1.4 DTS:X/ATMOS
(2016-04-05, 14:48)movie78 Wrote: I got most of the skin working the only that is not working are the OSD particularly VIDEO/AUDIO OSD
Maybe you can dig out something from scotts source, he has fixed that issue
https://github.com/scott967/Aeon_MQ5_Mod_Krypton
Try MQ5 Krypton Mod and look like it's working, I wish there someone a little more dev done the MQ6
Can any help me to this skin working woking with Kodi 17 Krypton?
This is current build that using Skin MOD - Skin MOD - Aeon MQ 6 - Moded version for I, J, K....
Movie78 MQ6 Krypton Build
The only thing not working is VIDEO OSD and AUDIO OSD
Enjoy!!!
(2016-04-19, 13:24)movie78 Wrote: Movie78 MQ6 Krypton Build
Enjoy!!!
Thanks alot Wink
Can I install that as .zip or does I have to extract it and put it in my Addons folder?
Enjoy!!!
Thanks alot Wink
Yes!
You can install as a zip...
Enjoy!!!
Thanks alot Wink
Yes!
Thanks Bro, but it didnt work. It doesnt showup under Skins, and its not in my Addons folder. I use the last Krypton build kodi-20160429-5ec2dfd-yab-tvos on my atv4.
(2016-05-18, 15:57)j0k3r Wrote: Thanks alot Wink
Yes!
Did you get any error when you were installing it?
Use MQ5 mod version with support krypton. Any other mod don´t work with Krypton alpha 2, settings areas have changes, GUI ID was update again, for 5.12.0
here image settings area in krypton now
[Image: 9NzdBm4.jpg]
MediaBrazil forum Website - Youtube Channel
Aeon MQ9-0.4.0 & Ace2 Skin Team
MarcosQui Website Donate and support us.
wiped Wink
(2016-05-18, 20:27)Wanilton Wrote: Use MQ5 mod version with support krypton. Any other mod don´t work with Krypton alpha 2, settings areas have changes, GUI ID was update again, for 5.12.0
With the MQ5 Version for Krypton, I got a xbmx gui error during the instalation. Tried the MQ6 mod from Movie78 and it runs fine on my atv4, I think the MQ5 version didnt work, because my atv4 have the Krypton alpha1 installed. The last tvOS build for Kodi is kodi-20160429-5ec2dfd-yab-tvos that is on my atv4 Wink
Glad to see it working for youCool, I wish we can get more Dev to support Aeon MQ6 for KryptonNo
...yea Wink but now with the Krypton alpha2 for atv4 the skin dont work anymore Oo
Krypton MQ6 From @Angelinas
Please post your bugs reports here.
  • 0 Vote(s) - 0 Average
[MOD] Aeon MQ 6 - Krypton by Angelinas00
