hi,
I would like to select/mark all movies with a specific range of IMDB rating, e.g. list all movies with rating < 5.
I see in the Movies Library view 4 filters (Custom # 1 etc)
If possible, how can I use these custom filters to filter based on IMDB rating?
HB
I use EMM version
In Settings -> Misc -> I don't have "Media List Editor"
I see a similar name: "Media Sources Editor" but that is different, I believe.
could this feature be for a higher version of EMM?
thanks
EMM what? You mean EMM 1.2 or revisited? Or 1.3.x or 1.4x or alpha?
Sorry for the typo, I meant 1.4.2.0
I whould change to the latest 1.4.8.0 Alpha. The database is a little bit slow atm, but that will be fixed in next Alpha release.
The Alpha is very stable and has a lot of new features. Most of the old settings will be recognized, but you have to check each setting. The old database will be upgradet during first run (need time).
2016-03-23, 22:03
(This post was last modified: 2016-03-24, 04:07 by hatbrox.)
I installed the latest version as a separate instance of EMM and created the filter as you suggested.
most of the time, the filter works.
there were movies without rating that were caught by filter (I'll change the SQL for that)
one movie with a rating of 10 was strangely also caught.
but it does the job.
2016-03-24, 16:40
(This post was last modified: 2016-03-24, 16:47 by calexicoca.)
<filename>-poster
<filename>-fanart etc
I changed that in expert filenaming setting but still missing? What I am doing wrong?
Each movie is in separate folder.
TV series also but the naming is just
I am trying to change but still nothing to see. NFO files are recognized, actors images too.
