After the update I have the bug of not waking up the device after some time. I deactivated the HDMI CEC and now it wakes up, but after some time pases, there is no audio in video apps or it just doesn't play, the videos stay on pause. I have to always restart, which is a pain in the arse.
There is a method of downgrading the device to Oreo on XDA. However, I tried it, but doesn't seem to work for me, dunno why. It just doesn't flash the device, although I followed the tutorial very carefully.
Did anyone managed to downgrade?
I can confirm the "no sound after waking up" bug with latest update. Xiaomi's programmers are a bunch of useless fucking idiots.
I'm quite new to Kodi and found after some research, that the "Mi Box" best fits my needs. I ordered one and then found this info of the broken latest update.
What should I do to install the lastest, working update (if it is not installed already). Btw. which is the latest update? There is the 5th November mentioned in the first post and then there is the firmware archive with the latest enty from 2018-06-26. I guess I can't just choose which update to install from the settings menu?!
Thanks and sorry for the newbish questions!
Alex
SWADED
Junior Member
Did they pull the update? I ignored the update at first, now it says there's now new update. I'm still on android version 8.0.0
cf7777
Junior Member
New v9 update also killed the bluetooth ear bud Audio quality.
Lots of crackling noise with BT ear buds.
I just installed Kodi 19 (matrix) and noticed that 7.1 (and atmos) audio doesn't passthrough correctly anymore. It outputs as 2.0 PCM for some reason. Tried the RAW and whatnot IEC options from the audio settings. DD and DD+ works normally. DTS i did not try. In 18.9 everything worked.
I have the old 2016 non-S mi box with Oreo.
Has anyone else tried Matrix and 7.1/atmos audio yet?
(2017-04-06, 06:08)wrxtasy Wrote: Quote:I just received this message because I have an a outstanding refund request.
Greetings! I understand your concern and I apologize for the inconvenience you have experienced. I would like to inform you that we are rolling out a new update on 7th April. You can install that and update and check, whenever you receive it. Please get in touch with us if you need any further assistance. Regards, Anant Xiaomi Customer Support
http://en.miui.com/thread-428000-17-1.html
I have just bought a Xiaomi MI Box S and I also have this red light coming out of the Audio opening at the back, when the MI Box S is switched off.
The red light keeps on changing from bright to weak and to off and on again al the time.
What is this MI Box S doing when it is switched off?
A second problem I have is that since I installed this MI Box S my Gigaset house phone does not show the weather info anymore after finishing a call.
When I take the current of the MI Box S, then my Gigaset House Phone shows the weather again. Why is this happening?
