OS X Best match downsampling not right....
Equipment: Macbook Pro, DragonFly 1.2 DAC. KODI. All software patched to latest versions.
I've set audio to best match bit rates. My DAC supports all bit rates up to 96khz, and best match works great up to this, but I have a number of files at 176.4 and 192 khz. Best Match resamples these at 44.1 and not 88.2 and 96khz respectively, which would be the best matches.
Is there any fix for this, apart from setting a fixed output at 96khz? Or should this be reported as a bug?
On my other setup, which has a DAC supporting sampling frequencies up to 192khz, best match works perfectly - but it's not called on to downsample.
cheers.
Best match downsampling not right....0
