i would like to purchase a z9s, my concern is that how is the performance of the smb of the z9s under 5G wlan. my experience is that the smb under android is very slow. i currently using kodi with webdav, and i can stream 4k remux under 5G withou any buffering.
or how is the zdmc look like? i can then use the webdav under zdmc just like under normal kodi?
thanks
@ hdmkv, Zidoo support is refusing to activate "ourglass" whitelabel / clone units anymore, so please confirm with them and update the post, as the device is useless without activation and on the other hand, seller does not respond at all.
Wow, really?! I'll remove the Ourglass recommendation from post #1. Zidoo hasn't been responsive of late in forums & such, and I'm no longer in direct e-mail contact w/them.
Ok, just whom, 'writes' all of these F/W updates of which there has been many?
2018-12-29, 21:17
(This post was last modified: 2018-12-29, 21:19 by AMST.)
As per seller feedback, they are genuine units manufactured by Zidoo with white label specific to seller's company "ourglass", but his company stopped their business and decided to sell the units on ebay.
2018-12-30, 01:16
(This post was last modified: 2018-12-30, 01:18 by hdmkv.)
Basically, the player doesn't function (won't let you open any apps) unless activated (using unique MAC address of unit) by Zidoo. Mine was upon e-mailing Zidoo support, but that was back in early September when I got my Ourglass unit. Doesn't seem like it's worth the risk now reading some of the feedback reviews on eBay.
What is the purpose of all of that??
Got mine right at the tip where they stop activating the device with the MAC address without activation the device is useless,great if you where able to get it at discount price activated by zidoo
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
so eseentially the x9s is best for 3D MVC stuff as it doesnt have stutters but if you us eit for any other material you get stutters?
