Can't import movies
Hi, I just installed Kodi to give it a try, I'm coming from JRiver. I have a few beginner questions I hope you don't mind helping with.
1. I tried importing some movies but Kodi doesn't find anything. I have a few mkv files in a folder D:\Movies. When I point to it to import movies, it indicates nothing was found.
2. Will Kodi play Blu Ray folder structure? Most of my movies are stored in this way on my drives. I'd rather not start converting them to mkv as a have about a 1,000.
3. I would like Kodi to decode my audio such as HD MA, DTS, etc and send as multi channel PCM to my Denon Receiver. I have the Audio set as Wasapi Denon, 5.1. Do I select Audio Passthrough? Not sure if I'm missing something...
Any assistance is welcome.
D
Ok figured out what I did wrong in number 1 above. Figured that out.
Might as well ask one more question. With JRiver I could use MADVR and Reclock. Is that possible with Kodi or do I even need them?
Can't import movies0
