nickr
Retired Team-Kodi Member
Then try paste.ubuntu.com. No one is interested in your mega link.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
OK. Link to Kodi log........http://paste.ubuntu.com/24464349/
Can you check that address. I have tried it twice and I just end up with an empty paste.
blossom24
Just tried it and it seems to take a while to load.
Ok, for some reason, the first 9768 lines are blank
If you wait it will populate the page.
Yes, that message
***Don't add tv shows with out official premiere date*** is right throughout your log.
Now I have tracked it back to this...
http://thetvdb.com/?tab=series&id=325447
For some reason, your scraper tries to scrape the above show. I don't know why.
So when you add the following Search String in the search box
** you end up with this...
http://thetvdb.com/?string=**&tab=listse...ion=Search (this is an English only search. There may be more in other languages)
At a guess, I would say that you scraped a TV Show, which was incorrectly entered at the TVDB, that listing has now been removed and been replaced with that warning.
If I am correct, it is a matter of figuring out which TV Show you have which previously matched that deleted entry.
DarklightIndigo at TVDB has modified the name of that problem show. It shouldn't happen again
https://forums.thetvdb.com/viewtopic.php?f=7&t=37128
Quote:Strange that it had worked this way for years. I guess that there has been changes in the scraper.
No, no change to the scraper. Just an incorrect entry at TVDB.
That problem show was only added to the TVDB on the 2017-03-14 at 12:22:41. It is the only entry in their database to use the words "TV Shows" in the title. So up until that date, people that had incorrectly set up TV Show sources had got away with it.
nickr
It was NOT a tvdb problem, it was a source setting problem in Kodi, Kodi was searching for a TV Series called "TV Series".
