Dull me....I really managed to remove the settings button from the shutdown menu. So now I have no more access to any settings. Any idea how to restore this?
PatK
Team-Kodi Member
2017-06-07, 18:58
(This post was last modified: 2017-06-07, 19:13 by PatK.)
I suppose you could delete C:\Users\Your_Computer_Name\AppData\Roaming\Kodi\userdata\guisettings.xml and it will return to default settings next launch. Or if you have that file in a back-up somewhere, inject it over top the existing file. Alternatively you could try changing this line: <setting id="Hide_Shutdown_Shutdown" type="bool">false</setting> in the C:\Users\Your_Computer_Name\AppData\Roaming\Kodi\userdata\addon_data\skin.transparency\settings.xml
