would like to see option to detach widgets from home screen and to enable circular navigation and would like to see option to adjust widgets like banner, poster, landscape, thumb,square and maybe even a banner with thumb mix. but other than that thx for the dev skin it looks very promisung alot of good and different options i havent seen before cant wait to see finished product. thx much
i meant detach widgets from menu
may i ask, if there is a krypton version of your skin?
Thanks and kind regards,
Peter
Jönke
Posting Freak
Q - works with pvr ?
Q- possible to make own pvr views ?
Good work
Its end of April where is alpha version. lol
I really like the way how this skin looks so far and I am also very curious if your alpha version of the skin is ready for release.
But don't rush it. It's done when its done. Again great work.
2018-05-13, 22:26
(This post was last modified: 2018-05-13, 22:30 by kow1234.)
3d viewmodes would be cool like 3d shelf and 3d list
is "beta1" out yet? I dont see the download link to it in the OP
