Stemy
Junior Member
Hello,
I'd like to see the visualization when i listen to music, but in the the visualizations, the only choice is «none» and the button «get more» is vanished. Did you deleted the functionality ? If so, why did you removed it partially ?
LibreELEC 11
Nvidia Geforce GTX 1050
Kodi 20
nickr
Retired Team-Kodi Member
Are you on ubuntu? If so I think they are installed via apt-get.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
jjd-uk
Team-Kodi Member
Or if on Android or Windows the Visualisation addons are disabled by default and must be enabled in My Addons.
jjd-uk
Team-Kodi Member
Have you enabled them in My Addons?
Stemy
Junior Member
I just did it, and it solved everything. But this is totally non-intuitive.
LibreELEC 11
Kodi 20
