Personally, I find Android pretty useless when it comes to (hifi) music because of limited samplerate and bitdepth support.
jjd-uk
Team-Kodi Member
For the same reason RPi is also a poor choice as it can’t do multichannel above 96khz
I gave up waiting for a solution.
Kodi is a very good mediaplayer for general use, and is even free.
Unfortunately, for my personal use case, playing dsf and other high resolution multichannel files, it's currently not usable.
So I switched to jriver.
Based on a ZOTAC ZBOX CI327 NANO hardware / Windows10, I now have a unit that plays multichannel dsf files and PCM 192/24 via hdmi.
SACD-ISO and dop is supported too.
If Kodi ever supports these formats again, I might switch back again
Please don't take this as bashing against Kodi,
in my opinion it's one of the best low cost multimedia solutions,
but it lacks support of hires audio formats.
So if dsf is a k.o. criteria you might have to look for another product.
regards
Udo
A bit off-topic, but other player alternatives that support SACD ISO are foobar2000 and AIMP.
